Hello!
I upgraded to HS3 finally and am working to create new events. I downloaded and installed BLRandom and was setting it up like HS2. After taking time to read, I saw that there is a different syntax so I copied and called myself editing the code. I get the script to work, but it actually pulls 2 phrases at a time when an event trigger happens! I know it's something simple, but can you please see what I'm missing? How should the code actually look like? Here is what I currently have:
Sub Main(byval param As Object) Dim message As String = hs.PluginFunction("BLRandom", "", "RandomizeGroup", new Object(){"Front Door Responses"}) hs.Speak(message, True) message = Nothing End Sub
