Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HAI/OMNI Panel for HS3 Plug-in (rmasonjr)
HAI/OMNI Panel for HS3 Plug-in (rmasonjr) Discussion about Rob Mason's HAI/OMNI Panel Plug-in
Closed Thread
  #41
Old March 15th, 2017, 09:27 AM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
OverSeer
Quote:
Originally Posted by madas View Post
Rolled back to .21 and did a test..it reconnected fine. I'll let it do its usual overnight automated thing either tonight or tomorrow and report back just to be 100% sure
Thanks for doing that - I can look at the changes between those 2 versions that could have caused it. I suspect the timer-interval polling of the system status.
64 Z-Wave Nodes, 162 Events, 293 Devices
  #42
Old March 15th, 2017, 11:29 AM
Pete's Avatar
Pete Pete is online now
OverSeer
Was that in response to me or someone else?
You.
There is a documented issue relating to too much network traffic hitting the OP2 NIC port which takes the network port down among other issues.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.435
  #43
Old March 15th, 2017, 11:32 AM
madas madas is offline
Seer Deluxe
Pete,
Yes I have hit that in the past actually when I was writing (poorly writing) some of my own scripts. In this case the panel is fine.
M
  #44
Old March 15th, 2017, 02:03 PM
Pete's Avatar
OverSeer
Ahhh...
Yes here it started to happen when I went close to 100 network devices on my home network. VLANs wouldn't help so I am routing the OP2 NIC today (layer 3) through a modded with OpenWRT travel router.
  #45
Old March 19th, 2017, 08:44 PM
neillt neillt is offline
Seer
Rob,
Updated HomeSeer today to 3.0.0.313 on Windows - and now the HAI Plugin is crashing before coming online fully. HS keeps trying to restart it to no avail.
The logs show it connecting to the panel fine, syncs up to the panel, updates HomeSeer, and then something is making it crash. Last few lines of the log before it crashes and restarts:
3/19/2017 5:40:23 PM [2]  [Flag [474]  status=[0]  [0]]
3/19/2017 5:40:23 PM [2]  [--> Flag 474 changed status.  Updating Homeseer...]
3/19/2017 5:40:29 PM [1]  [Synchronization complete.]
3/19/2017 5:40:29 PM [1]  [---------------------------]
3/19/2017 5:40:29 PM [1]  [Plugin startup is complete.]
3/19/2017 5:40:29 PM [2]  [Humidity Zone 10 changed status. Reading=[0]]
3/19/2017 5:40:29 PM [2]  [Zone [10]  Humidity-->0]
3/19/2017 5:40:29 PM [2]  [Temperature Zone 11 changed status. Reading=[0.0]]
3/19/2017 5:40:29 PM [2]  [Zone [11]  Temperature-->0]
**  This is when it crashes
3/19/2017 5:40:57 PM [1]  [INIFILE set to: HAI.ini]
3/19/2017 5:40:59 PM [2]  [HAI Plugin Thread was started.]
3/19/2017 5:41:00 PM [2]  [Initializing Timers...]
3/19/2017 5:41:00 PM [2]  [Device initialization is complete.]
3/19/2017 5:41:01 PM [2]  [HAC Connection state is: Offline]
3/19/2017 5:41:01 PM [2]  [Connecting with: [192.168.71.8] [4369] [TCP]]
3/19/2017 5:41:01 PM [2]  [CONNECTION STATUS: Connecting]
3/19/2017 5:41:01 PM [2]  [Panel Connected.]
3/19/2017 5:41:01 PM [2]  [Identifying Controller...]
3/19/2017 5:41:01 PM [2]  [CONTROLLER IS: OmniPro II (4.0B)]
3/19/2017 5:41:04 PM [1]  [-->Reading configuration...]
3/19/2017 5:42:17 PM [1]  [-->Reading properties...]
3/19/2017 5:42:20 PM [2]  [MapZoneStatus_V2: zoneId=[1] status=[1] zoneChanged=[False] annotation=[Z1] statusText=[NOT READY] zoneType=[64] zoneTypeText=[Auxiliary] name=[Sprink Actv] area=[1] analogLoop=[253] isNamed=[True] lastStatus=[0] lastStatusText=[] statusLastChangeDate=[3/19/2017 5:42:20 PM] isSecurityZone=[False] isArmingZone=[False] hsDeviceRef=[0] hsParentRef=[0] temperature=[0] humidity=[0] currentCondition=[0] currentStatusText=[NOT READY] hsZoneStatus=[0]]
3/19/2017 5:42:20 PM [1]  [All configuration and properties retrieved.]
Any insights? I can provide more details if needed of course....
  #46
Old March 20th, 2017, 09:51 AM
rmasonjr's Avatar
OverSeer
Quote:
Originally Posted by neillt View Post
Rob,
Let me take a look at the code around those log entries and get back to you...
  #47
Old March 20th, 2017, 01:02 PM
rmasonjr's Avatar
OverSeer
Rob,
Neill - can you send me your logs? I think there might be an exception in there that I'm not seeing here.
Let me know...
  #48
Old March 20th, 2017, 07:09 PM
Seer
Quote:
Let me know...
Not a problem, but there really isn't much more in it than what I already posted.
I'll e-mail them over here in a second.
Closed Thread
HTML code is On
HAI Plugin Beta - v3.0.1.13 rmasonjr HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 132 March 18th, 2016 07:20 PM
HAI Plugin Beta - v3.0.1.12 rmasonjr HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 33 January 19th, 2016 01:13 PM
HAI Plugin Beta - 3.0.1.3 rmasonjr rmasonjr Plug-Ins 82 August 14th, 2015 04:03 PM
HAI Plugin v1.0.0.11 Beta rmasonjr rmasonjr Plug-Ins 12 July 28th, 2014 10:19 PM
