Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > rmasonjr Plug-Ins
rmasonjr Plug-Ins Discussion area for plug-ins by Rob Mason
Old June 30th, 2015, 12:00 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
HAI Plugin Beta - 3.0.1.3
Version 3.0.1.3 was submitted to the updater this morning. It might be a little while before it shows up in the updater.
Changes in this version:
  • Added output control buttons to the device management page.
  • All Child devices now use name/value pairs for PED.
  • Refactoring older code.
  • Added routine to update devices - no more removing devices for plugin update.
  • Fixed issue with Outputs not updating HS with initial status.
***Backup your current installation so you can revert back if needed!!
Note - No longer necessary to remove devices before updating plugin versions.
Old June 30th, 2015, 12:49 PM
Pete's Avatar
Pete Pete is offline
Thank you Rob!!!
Automator
Old June 30th, 2015, 02:59 PM
rmasonjr's Avatar
Thanks Pete. The source code is much more structured than when I began, so I'm able to make changes a little faster/easier now.
Old June 30th, 2015, 04:16 PM
Daweeze's Avatar
Daweeze Daweeze is offline
Hey Rob,
Wow, these updates are happening fast...awesome! Had a couple of questions regarding the release (still not yet available) and the items below:
Originally Posted by rmasonjr View Post
[*] All Child devices now use name/value pairs for PED.[*] Fixed issue with Outputs not updating HS with initial status.
1) Not sure what the PED comment is and what might this affect?
2) Does the issue fixing the Outputs also address the Zone initial status problem as well?
Looking forward to testing. Thanks for all the effort!
-Travis
Old June 30th, 2015, 04:26 PM
rmasonjr's Avatar
Originally Posted by Daweeze View Post
Hey Rob,
-Travis
Hey Travis:
PED is Plugin Extra Data and is a way for developers to store some information in each device that is created, usually information that is specific to a plugin. Prior to this release, I was storing a custom class and I moved it to simple name-value pairs. The user wont notice anything on the surface - this is all under the hood.
I think fixing the Output's initial status should have fixed the Initial Zone status as well. Try it out and let me know. My panel is still not configured nearly as much as you guys - I'm slowly building my system.
Yeah, prior to the 3.x.x.x release, the source code was not structured very well. Now that I have it in a form that is much easier to make changes.
The updater process is a little slow. I'll ping the updater group at HST and see when it will be posted.
Old June 30th, 2015, 04:47 PM
Daweeze's Avatar
Awesome, thanks for the info Rob. I will test as soon as it's available and I have a chance to install.
-Travis
Old June 30th, 2015, 05:38 PM
Pete's Avatar
Installed update a few minutes ago.
It is shutting down and restarting itself. I went to look at the console and see this.
6/30/2015 4:44:40 PM--INIFILE set to: HAI.ini
6/30/2015 4:44:40 PM--Starting threads.
6/30/2015 4:44:42 PM--HAI Plugin Thread was started.
6/30/2015 4:44:42 PM--Initializing Timers...
6/30/2015 4:44:42 PM--Checking root devices for HAI...
6/30/2015 4:44:43 PM--Device initialization is complete.
Unhandled Exception:
System.NullReferenceException: Object reference not set to an instance of an object
at HSPI_HAI.Util.CheckDevicesForUpgrade () [0x00000] in :0
at HSPI_HAI.HSPI.HAI_Proc () [0x00000] in :0
at System.Threading.Thread.StartInternal () [0x00000] in :0
[ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object
updating devices
Will try maybe deleting all of the HAI devices?
Shut down plugin and deleted all of the HAI devices.
Started up the plugin and it created all of the devices. No errors were seen in the console log.
Plugin is running now without shutting down.
Will enable mysql db logging in a bit.
BTW I have been able to watch the console via Webmin by using a cron job to start HS3 instead of using Upstart.
Cleared mysql db via HeidiSQL.
Enabled mysqldb logging.
Old June 30th, 2015, 05:57 PM
Daweeze's Avatar
Hi Pete,
I am not seeing that at all. I upgraded from the latest 3.0.1.2 (2nd 3.0.1.2 Manual file replacement version) and so far all is well.
-Travis
Old June 30th, 2015, 06:10 PM
Pete's Avatar
Yup; here had also updated manually to last version posted 3.0.1.2.
The above went away when I shut down the plugin. Deleted all of the HAI variables. Turned on the plugin. I saw no more issues in the console.
I did have an extra or double output and I think it was a straggler after I had defined one output. Not sure.
When it created all of the output variables they were fine this time. Thinking I saw the double output when I defined one output?
Turned on DB and checked just now at ~600 rows. Looks good.
I do not see any temperature queries in the mySQL logs at this time.
Old June 30th, 2015, 06:22 PM
Daweeze's Avatar
Hi Rob,
Just some notes I have so far:
1) I had to remove my Output Devices and reimport them (Turn off/on in your web menu) to enable to the Controlled Output capability. I tried to manually apply the controls to the original devices but they still didn't show up. All good and testing functional now. I kind of expected this but you may want to note that is necessary.
2) The Initial status update appears to be working on the Zones and Outputs (Exceptions noted in #3 below). This fixed the majority of my initial status issues and graphics not appearing in the HS Device List.
3) The following status items do not yet update initially. I suspect it is due to the fact they are different sensors or have different Zone Status types or conditions that are not recognized. They do not present a graphic or status in the Device List.
1) Keyfob Panic Button - Zone Type=Panic (7 of 8 other buttons appear ok, not Panic type though)
2) Carbon Monoxide Sensors - Zone Type=Gas
3) Window Sensor - Zone Type=Auxiliary (Window is Bypassed)
This is what they look like in the HAI Plug-in Zone Web Page:
# Annotation Status Name Area Loop Zone Type isSecurity? isArming?
085 (EE3-5) SECURE Keyfob1-Button4 Travis - Keyfob - Button 4 - Panic! 1 10 Panic True True
053 (EE1-5) SECURE Upstairs - CO CO Detector 1 148 Gas True False
067 (EE2-3) SECURE Aubrie - Window Window 1 20 Auxiliary False False
I am not sure what items are considered complete for Zones at this point so I am not sure what to report as a bug vs something that isn't supported yet.
Thanks again Rob!
-Travis
Old June 30th, 2015, 08:17 PM
Pete's Avatar
Looking good here Rob.
Did a quickie test on the outputs using PCA to manually turn on and off an output.
Instant status on the HAI output page. Then did same on the HAI output page to PCA.
Instant status on PCA.
Been using NOAA radio with wireless switches and now moving the NOAA radio output to one zone to test with WeatherXML.
~1000 mysql database entries and doing fine.
Old June 30th, 2015, 09:54 PM
rmasonjr's Avatar
Hi Rob,
#AnnotationStatusNameAreaLoopZone TypeisSecurity?isArming?
085(EE3-5)SECUREKeyfob1-Button4 Travis - Keyfob - Button 4 - Panic!110PanicTrueTrue
053(EE1-5)SECUREUpstairs - CO CO Detector1148GasTrueFalse
067(EE2-3)SECUREAubrie - Window Window120AuxiliaryFalseFalse
Thanks again Rob!
-Travis
Great info, Travis. I do need to check the HAI protocol docs for those zone types. It might be as easy as just adding those zone types.
Sorry you had to delete/read the devices. I thought my new routine would have worked
Sent from my Xoom using Tapatalk
Old June 30th, 2015, 09:58 PM
rmasonjr's Avatar
Thanks Pete. That's exactly how I tested things - with PC access.
I am very interested in your NOAA connection to the hai panel. If I understand, you'll signal a zone when the NOAA alert goes off?
Old June 30th, 2015, 10:24 PM
Pete's Avatar
Yes. Thank you Rob for a great plugin.
Been using it with the Homeseer 2 box. The radio is programmed for just local alerts.
There is a NO switch on the radio which goes to NC when a NOAA alert is triggered.
First have Homeseer generate a TTS with alert.
Then an event triggers to screen scrape the NOAA alerts then read the alert.
See here.
Weather radio integration for automation
Old July 1st, 2015, 08:58 AM
rmasonjr's Avatar
See here.
Very nice, Pete!
On a related note, I have two driveway sensors being shipped from Amazon. I'll wire these into my HAI panel to alert me, via the plugin, when cars approach my house.
Old July 1st, 2015, 09:24 AM
Pete's Avatar
@Rob,
Yup; here use two Cartell sensors (well its been over 10 years now) buried under the driveway and wired to the panel, PIRs and CCTV (4 cams) plus a couple of other devices all wired to the panel.
I do have the two HAI wireless devices (HAI 45A001 X 2 and one LV42A002) but have never used them in the midwest. I use one in FL today.
Using the little cheaper RFID devices in the house cars. They work fine today after many years. I tested these out a few months ago and they do work a few hundred feet away. These devices are the only wireless devices that I use outside.
Yesterday this little rabbit in the picture triggered a few events with home seer. It was playing and hopping around that cable you see in the picture. Never seen a rabbit jump that high.
The event/rabbit though reminded me to call CC today about burying that cable that has been sitting there now for over a month which sort of po'd me today.
Old July 1st, 2015, 10:58 AM
rmasonjr's Avatar
Ah - those Cartells look nice. A friend recommended the Mighty Mule driveway detectors. They are buried next to the driveway and detect large metal objects which reduces false alerts. They seem to have very long range back to the receiver.
From the receiver, I want to connect it to my HAI panel as a zone. From there, I can trigger camera snapshots, TTS alerts, etc.
We've had an influx of rabbits down here in MS too! The kids love to see them.
Old July 1st, 2015, 11:18 AM
Pete's Avatar
I have read good stuff about the Mighty Mule driveway sensors.
Here many years ago ran much PVC underground to use for automation when it was time to use it.
You can do a bunch from the panel and integration with Homeseer.
Yup; here wife enjoys watching the rabbits. (we have seen coyotes, owls and hawks doing their stuff here sometimes).
BTW - did a quickie test while doing some other stuff with the panel today disconnecting it for a time. When I reconnected the network interface the HAI plugin came right back up and connected just fine.
HAC Connection is Offline...2015-07-01 14:35:09
Requesting configuration and properties of panel...2015-07-01 15:00:25
All of the OPII connected devices came back up fine except for the Omnitouch 5.7e's.
I had left my micro router just sitting there hanging a bit loose and neatened it up a bit using those clear 3M dual lock velcro tabs. Good stuff. It is being powered by the OPII panel (and backup).
Old July 5th, 2015, 12:22 PM
ray ray is offline
Hi Rob,
What is the purpose of the MySQL logging? I can see that it is logging the communication between HAI panel and the Homeseer plugin. Is the purpose to log the communication? or is there another purpose I'm not thinking of?
I was also wondering if you could utilize SQL logging that Jon uses in his charting program. I'm not a SQL expert but it seems like the MySQL Jon uses is a lot easier to use and does require a separate SQL program. Jon charting program uses MySQL to save data into a database (which I can view and export with free program).
Like I said, I'm not a expert. I'm just trying to understand the advantage of MYSQL.
Ray
Old July 5th, 2015, 08:01 PM
rmasonjr's Avatar
Hey Ray. There's an HAI logging utility that has made its rounds over on CT. Its useful to have the logging to a db for history purposes. For example, you could go back pretty far to search for any panel activity.
Right now, my plugin only logs messages. I think Jon is logging actual device history info which is very helpful in tracking specific device activity.
HTML code is On
HAI Plugin Beta - 3.0.1.1 rmasonjr rmasonjr Plug-Ins 49 June 30th, 2015 12:01 PM
HAI Plugin Beta - 3.0.1.0 rmasonjr rmasonjr Plug-Ins 51 June 23rd, 2015 09:07 AM
HAI Plugin v1.0.0.21 Beta rmasonjr rmasonjr Plug-Ins 22 April 21st, 2015 10:44 PM
DSC Plugin Beta 2.0.0.12 rjh HomeSeer DSC Plug-in 10 March 2nd, 2011 10:26 PM
DSC Plugin Beta 2.0.0.7 rjh HomeSeer DSC Plug-in 9 February 18th, 2011 05:31 PM
