NO Homeseer menu under Extra's Menu
    I have just downloaded and installed the SqueezeBox plug-in on HomeSeer 2.3.0.19 and SqueezeCentre 7.3. I have followed the full installation requirements as per the Users Guide pdf. Homeseer seems to have control over the SqueezeCentre, so communication has been established from Homeseer to SqueezeCentre. I can start, stop, play, pauze etc. and it all works. However, the User Guide also mentions that the SqueezeCentre controller will be able to control devices in Homeseer, throught the Extra's menu. Although I have installed the SqueezeCentre plug-in in SqueezeCentre, there is no submenu in Extra called Homeseer or anything similar. Can you tell me how to activate this menu ??? I have activated the plug-in in SqueezeCentre settings section and entered the required path settings. Both Homeseer and Squeeze Centre are running on same PC. I have restarted the SqueezeCentre service and restarted the application, same with Homeseer, but still to no avail. Have I missed out something ??
    Kind Regards,
    Harry van der Vossen
