I submitted this trouble report to Homeseer support, who then asked that I post it here. This problem happened during startup, after an uncontrolled shutdown (power failure).
Otherwise, the plug-in appears to be working OK.
Any ideas as to what went south? Thanks very much in advance!
2/5/2009 9:12:19 PM
A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied
HomeSeer version: 2.3.0.19
Source: System
Target: Void Shutdown(System.Net.Sockets.SocketShutdown)
Stack trace:
at System.Net.Sockets.Socket.Shutdown(SocketShutdown how)
at HSPI_SQUEEZEBOX.hs_socket_io.sockConnected(IAsyncResult ar)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.ContextAwareResult.CompleteCallback(Object state)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWi thGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionConte xt executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Net.ContextAwareResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Sockets.Socket.ConnectCallback()
at System.Net.Sockets.Socket.RegisteredWaitCallback(Object state, Boolean timedOut)
at System.Threading._ThreadPoolWaitOrTimerCallback.PerformWaitO rTimerCallback(Object state, Boolean timedOut)
Source: System
Stack trace:
