Buttons in HS Touch to play BBC Radio on Squeezebox
    I'm not sure if this is possible within the current boundaries of the plugin, but I am envisioning a set of buttons on HS Touch that say 'BBC Radio 1' 'BBC Radio 2' etc, upon pressing, HS activates a particular squeezebox, and starts streaming the relevant BBC radio stream using the AlienBBC plugin.
    Is this a bit too ambitious, or possible within the current feature set?
    Jon
    Wouldn't you be able to setup an event to do what you want, (if that's possible with the Squeezebox Plug-in) and then call that event from HSTouch?
    Marty
      That's what I am hoping, although I'm not sure if I can be that selective with what I can pass from HS to the Squeezecenter. I am hoping that someone can point me in the right direction - I guess i just want to know its possible...
      Jon
        I just posted a beta version for testing and feedback that supports interacting with the player's playlist (add, insert, etc). See http://board.homeseer.com/showthread.php?t=133690
        I have not tried (yet) the actions and apis with specific radios but don't see a reason why it would not work. Otherwise you can create playlists for the radios and specify those as the item to play (see my screenshot in http://board.homeseer.com/showthread.php?t=133690).
        In the mid to longer term I hope to support the HS2 multizone and media APIs which would make it easier to integrate with HS Touch (per discussions with Rick).
          Excellent - thank you - will try it out now.
          I don't have a squeezebox (I use squeezeslave) but already your plugin seems to be a more versatile solution for audio in HS than the iTunes and Media Player plugs. I think I could do all my audio via squeezeslave - will try to see if i can run more than one instance on the same box
          Jon
