Originally posted by beerygaz
View Post
I assume you are on version 3.0.0.3 for the Sonos PI?
There was a bug in V3.0.0.2 were the sourcezone, although it appears correct in the web config page is actually not saved in the .ini file. Could you either delete and recreate the linkgroup entries or just select a different player in the source player field (any different selection automatically writes it to the .ini file) and set it back to the source zone player you wanted. If you created this linkgroup table entry and the source zone player that showed up in that drop-down was the one you liked, the info wasn't stored. This was fixed in V3.0.0.3 but only when you create new linkgroup entries.
If all else still fails, make sure you turn the debug flag on and capture all. Also would like to see screenshot of event that you use and config page.
Dirk
