Originally posted by rjh
View Post
Alexa room access
Originally posted by randman View PostSo, what would be the advantage using the native skill then?HomeSeer Version: HS3 Standard Edition 3.0.0.548
Both skills with be active, you can pick the one you want or use both at the same time.
As for Denmark, see if the SmartHome skill is available now, we have the version 2 skill available in the EU so I think it should be working. If you see it, then the version 3 skill will work when its released.
Originally posted by ldplusse View PostCan i use this new skill in Denmark, when it is released. (I have to talk english of course).
Will 'HomeSeer Smart Home' replace 'HomeSeer Home Automation Skill'?
Rich, any updates on the release of the next version? Last I remember, you had submitted it to Amazon and are awaiting for them to certify, correct?HomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
They came back twice with some issues with our sample voice commands in our skill description. So I assume everything else is ok. We made the changes and submitted again this morning. Hopefully we are close now.
On the plus side we did just add lock support to the Google Assistant and that is active now.
Originally posted by Krumpy View PostRich, any updates on the release of the next version? Last I remember, you had submitted it to Amazon and are awaiting for them to certify, correct?
Originally posted by rjh View PostThey came back twice with some issues with our sample voice commands in our skill description. So I assume everything else is ok. We made the changes and submitted again this morning. Hopefully we are close now.
On the plus side we did just add lock support to the Google Assistant and that is active now.Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Guest
Guest
Got the new version of the skill installed. I have an Echo in my Kitchen, and it's in a smart home group with the switch that controls the kitchen light. Unfortunately, when I say "Alexa, turn on the light", it says "Sorry, I didn't find light" rather than turn the light on. If I add the dining room light (an Insteon Dimmer - shows as "Type: Light") to the smart home group, "Alexa, turn on the light" will turns the dining room light on and off with no problem. I think the issue is that Insteon on/off switches are being presented as "Type: Switch" rather than "Type: Light" ... Is there any way for me to get my On/Off switches to show as lights, instead of switches?
Answered my own question: latest betas of HS3 Pro have a checkbox in the device's configuration page for "Is light". Checking that and doing a discovery on Alexa corrected the problem.
Originally posted by whippersnapper View PostGot the new version of the skill installed. I have an Echo in my Kitchen, and it's in a smart home group with the switch that controls the kitchen light. Unfortunately, when I say "Alexa, turn on the light", it says "Sorry, I didn't find light" rather than turn the light on. If I add the dining room light (an Insteon Dimmer - shows as "Type: Light") to the smart home group, "Alexa, turn on the light" will turns the dining room light on and off with no problem. I think the issue is that Insteon on/off switches are being presented as "Type: Switch" rather than "Type: Light" ... Is there any way for me to get my On/Off switches to show as lights, instead of switches?
Guest
Rich,
No it does not stick.
Thanks it is working now! But had to remove all the devices in Alexa and reads them.
And named them one by one in the in the new box in HS3 device control . I missed that box !
