Answer to post #15 could be as I show in the image below but that will set all ON/OFF devices state wide. Follow the link to image ("My documents Folder")
Now if you have found the HSTouch folders, Save them somewhere first before if you are not confident but I can assure if you reinstall HSTouch they are all replaced and your own created projects saved (someone quote me wrong!)
Why I say save (you save the XML file under a new name) and deploy is because the updated file is not on the Android client!
HomeSeer server must be connected to the Designer while doing this.
The magic which pulls your devices and events is within the client app. That's why the author in video in the link I posted earlier dose not want you to alter but anything else is fair game. Look on the left to see your devices and or elements. You can even add to or remove from those screens!
PLEASE NOTE : The links I post on the forums are safe. I have a feeling you not reading my posts because of the links!
The link to the beta HSTouch Designer : https://forums.homeseer.com/showthread.php?t=180150
Eman.
Eman.
