Help adding replacement Somfy (Bali) blind into system
    One of my blinds failed and I received a replacement from the factory. I just paired it with my original remote (a Telis RTS 5 channel).
    I can't remember how I added this blind to the RFXCOM in the first place so I am trying to recreate my steps. I am looking in chapter 9 of the RFXtrx user guide.
    It says to select a unique unique ID and unitcode for the RFXCOM RFY device.
    My question is - as I am replacing an existing blind with the exact same model - can I use the existing RFXCOM output device?
    Also, according to the settings in the original device I see that I originally set a device code of 1 and ID code of 0,00,00. It would seem that I should have set an ID code when I setup the old blind?
    What would be the recommendation for setting up the replacement blind? Thanks.
    You can use the same ID-unit code for the replacement motor or select a new ID.
    The ID should be different from all zeroes.
    Put the motor in pairing mode with the Somfy Telis remote.
    Transmit a program command from the HS device.
    That's all
      Thanks - worked like a charm.
