Now trying 40 still getting WARNING: Failed getting InterfaceStatus from BLBackup - the interface was not found in the list of active interfaces, the list may need to be refreshed.
Not work since .36
Mine has not run in a couple of days. I just updated to .41. We will see what that will do.
MichaelHS3Pro & HS4Pro on Win2012R2
Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
Originally posted by Jobee View PostMine has not run in a couple of days. I just updated to .41. We will see what that will do.
Michael
My logs indicated that it ran... but didn't.
Mar-07 1:00:00 AM Event Event Trigger "System Maintenance BLBackups"
Hopefully it will run now.
Bob, where can we go to, to view the changes made in each release?
Robert
EDIT: Running the event manually with .41 works. I suspect it will run at the next scheduled backup.HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Hi Bob,
Originally posted by Blade View PostYou may have to re-create your BLBackup event actions
Let a backup run first and see before changing the event actions
Mar-07 14:52:15 Warning In ZipFile, exception opening C:\Program Files (x86)\HomeSeer HS3\Data\ultralighting3\ultralighting3.db3 : The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Data\ultralighting3\ultralighting3.db3' because it is being used by another process.
Mar-07 14:52:14 Warning In ZipFile, exception opening C:\Program Files (x86)\HomeSeer HS3\Data\HSBuddy\hsbuddy.db3 : The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Data\HSBuddy\hsbuddy.db3' because it is being used by another process.
Mar-07 14:52:03 Warning In ZipFile, exception opening C:\Program Files (x86)\HomeSeer HS3\Data\BLBackup\BLBackup.s3db : The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Data\BLBackup\BLBackup.s3db' because it is being used by another process.
I looked in the HS3 log files going back a month and have never had this warning with the backup.
I did get the notice the backup was a success. How can this be if it did not backup the files noted above?
Michael
BTW - THANK YOU for putting SUCCESS in the subject of the email. It is huge help. Now I can turn off my other events.
Blade,
After upgrade to .40 the backups stopped. The daily event fired and I got the following message in Log:
"Event BackUps All HS3 To BobsOfficePC, Action of BLBackup: Start Backup could not be carried out because its configuration is not complete. "
Your status Device did not indicate an error/incomplete Backup--it just stayed with the previous days "complete" message. Is that how it should have worked? I hope not.
Today I upgraded to .41, then tried to manually trigger the BU Event. In the log it indicated the BU event was triggered but nothing happened. The status device was unchanged(still indicating the successful BU BEFORE the upgrades).
Also your BU log reports show nothing since before the .40 Upgrade!
BobSpen
