test for all secure
    test for all secure
    Is there a way to test (other than going through each zone) whether or not all zones are secured (the system is ok)?
    What you should be able to do is create a HS virtual device to store the status of all zones and build events to update that virtual device. It would take a bit of work to build the events, but should work fine.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      You can setup one of the outputs to be of type "OK To Arm" and just monitor its status.
      There is another output type "Armed" to indicate the panel is in a mode other than Off.
      Page 17 of the Installation Manual describes this output type.
      Page 35 has a chart of the available types.
