I had to replace my wireless router today. I am getting this error on start up of HS3....
~!~Warning~!~Error starting web server, port in use? Are you running a web server on the designated port? Edit settings.ini in the Config folder and change gWebSvrPort=## to a different port #. The requested address is not valid in its contextStartup Complete...
Also when I look in the log I have these messages.....
11/22/2017 5:47:29 PM ~!~Web Server~!~Local IP address (subnet) is: 192.168.1.8 (255.255.255.0)
11/22/2017 5:47:29 PM ~!~Web Server~!~UPNP Discovery started
11/22/2017 5:47:29 PM ~!~Web Server~!~The web server has been bound specifically to IP address 192.168.1.4
11/22/2017 5:47:29 PM ~!~Web Server~!~Web Server started on IP Address 192.168.1.4, port 80
11/22/2017 5:47:29 PM ~!~Warning~!~Error starting web server, port in use? Are you running a web server on the designated port? Edit settings.ini in the Config folder and change gWebSvrPort=## to a different port #. The requested address is not valid in its context
11/22/2017 5:47:29 PM ~!~Warning~!~Web Server Stopped
I can no longer get my device utility to open. It keeps trying to open it in the old IP Address. The new router gave my Homeseer server an new IP Address. Any Idea how to fix it. I have been trying for a few hours now.
Thanks in advance, Mike
