Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3Touch™
HS3Touch™ Discussions regarding HS3Touch touchscreen software for HomeSeer HS3
Old March 13th, 2016, 07:18 PM
Gallina's Avatar
Gallina Gallina is offline
CAPI
What is meant by the term "CAPI" in my log I have lines saying by/from: CAPI Control Handler.
Old March 13th, 2016, 07:44 PM
Blade's Avatar
Blade Blade is offline
Device Control API
Cheers,
Bob
Old March 15th, 2016, 10:17 AM
Gallina's Avatar
CAPI
Thanks for the reply but it doesn't really tell we what it is so I can correct the problem. It continues to turn on my basement lights through out the day.
Old March 15th, 2016, 10:23 AM
mrhappy mrhappy is offline
What CAPI is a common method for HS to control devices, plugins themselves handling the actual communication with the devices.
Why you find your lights turning on/off is another matter, at least it is happening inside HS so you should be able to find out what is responsible for it.
Are you able to post some of your log, immediately before the light on/off does it show anything that might say event trigger? Is there any pattern to the on/off cycle, exactly every hour?
Another worthwhile thing is to go into the events page, using the drop down at the top select the light and then see what events control that device. Check the triggers for these events, see the last run times of the events and see whether they match the lights on/off times.
HTML code is On
CAPI for scripts bdickhaus HS3 Plug-In Development 10 March 4th, 2018 11:38 AM
CAPI Questions jwshome2 HS3 / HS3PRO Discussion 5 March 20th, 2016 07:10 AM
OK Capi!!! Help Gogs HS3 Scripting 35 April 24th, 2015 05:11 PM
CAPI? MrSkippy HS3 Scripting 2 April 4th, 2014 06:54 AM
Help with CAPI please naellis HS3 Scripting 4 March 26th, 2014 09:03 AM
