Unable to poll devices
    After installing the plug-in it looks updating devices fails for all of them. The list of devices under Select devices that require polling and Select devices that require active checking is empty and logging shows battery child not found. My devices are mainly Fibaro and some aeonlab devices.
    apr-12 10:43:22 SDJ-Health Device #112 doesn't have a battery child so won't be monitored!
    apr-12 10:43:22 SDJ-Health 1 queued messages processed
    apr-12 10:42:17 SDJ-Health Wake-Up Device #112 added to message queue for processing.
    apr-12 9:47:21 SDJ-Health 1 queued messages processed
    apr-12 9:47:21 SDJ-Health Failed to find battery child.
    apr-12 9:47:21 SDJ-Health Device #210 doesn't have a battery child so won't be monitored!
    apr-12 9:46:19 SDJ-Health Wake-Up Device #210 added to message queue for processing.
    apr-12 9:43:21 SDJ-Health 1 queued messages processed
    apr-12 9:43:21 SDJ-Health Failed to find battery child.
    apr-12 9:43:21 SDJ-Health Device #112 doesn't have a battery child so won't be monitored!
    apr-12 9:41:58 SDJ-Health Wake-Up Device #112 added to message queue for processing.
    apr-12 9:25:21 SDJ-Health Failed to find battery child.
    apr-12 9:25:21 SDJ-Health Device #118 doesn't have a battery child so won't be monitored!
    apr-12 9:25:21 SDJ-Health 1 queued messages processed
    apr-12 9:23:27 SDJ-Health Wake-Up Device #118 added to message queue for processing.
    apr-12 8:43:21 SDJ-Health Device #112 doesn't have a battery child so won't be monitored!
    apr-12 8:43:21 SDJ-Health 1 queued messages processed
    apr-12 8:43:21 SDJ-Health Failed to find battery child.
    apr-12 8:41:39 SDJ-Health Wake-Up Device #112 added to message queue for processing.
    apr-12 8:27:52 SDJ-Health Polling devices stopped.
    apr-12 7:57:21 SDJ-Health Failed to find battery child.
    apr-12 7:57:21 SDJ-Health Device #243 doesn't have a battery child so won't be monitored!
    apr-12 7:57:21 SDJ-Health 1 queued messages processed
    apr-12 7:55:31 SDJ-Health Wake-Up Device #243 added to message queue for processing.
    apr-12 7:49:21 SDJ-Health Device #54 doesn't have a battery child so won't be monitored!
    apr-12 7:49:21 SDJ-Health 1 queued messages processed
    apr-12 7:49:21 SDJ-Health Failed to find battery child.
    apr-12 7:47:40 SDJ-Health Wake-Up Device #54 added to message queue for processing.
    apr-12 7:47:21 SDJ-Health Failed to find battery child.
    apr-12 7:47:21 SDJ-Health Device #210 doesn't have a battery child so won't be monitored!
    apr-12 7:47:21 SDJ-Health 1 queued messages processed
    apr-12 7:46:21 SDJ-Health Wake-Up Device #210 added to message queue for processing.
    apr-12 7:41:21 SDJ-Health 1 queued messages processed
    apr-12 7:41:21 SDJ-Health Failed to find battery child.
    apr-12 7:41:21 SDJ-Health Device #112 doesn't have a battery child so won't be monitored!
    apr-12 7:41:19 SDJ-Health Wake-Up Device #112 added to message queue for processing.
    apr-12 6:41:20 SDJ-Health Device #112 doesn't have a battery child so won't be monitor
    One the devices that fail shows this after scan:
    Node: 8 Supports Class(es): SENSOR_BINARY, WAKE_UP, ASSOCIATION_V2, BATTERY, MULTI_CMD, CRC_16_ENCAP, MANUFACTURER_SPECIFIC_V2, VERSION_V2, CONFIGURATION_V4, MULTI_CHANNEL_ASSOCIATION_V3, SENSOR_MULTILEVEL_V7, SENSOR_ALARM
    Hi voxie
    Sorry you are having problems with the pi.
    Using the Node 8 example can you give me a screen shot of the 'Advanced' tab for both the Node 8 Root device and for the Node 8 Battery Child.
    Steve
      Hi Steve,
      Tnx for your quick reply. This is the info on the root and battery child from node 8:
      Reference ID 210
      Technology Address 014CE485-008
      Status 0 = OFF
      Value 0
      String No Status
      Supports Status False
      Dimmable False
      Interface Z-Wave
      Extra Data Store 37 Named entries, 0 UnNamed entries.
      Device Type Internal Plug-In API, Type: Plug-In Root Device, SubType: On/Off Sensor
      Device Type (String)
      Z-Wave On/Off Sensor Root Device
      Misc Settings Status Only
      Relationship Status Parent Root
      Associated Devices 8 gang Sensor gang batterij, 8 gang Sensor gang Vibration, 8 gang Sensor gang, 8 gang Sensor gang temperatuur, 8 gang Sensor gang licht, 8 gang Luminance
      Reference ID 211
      Technology Address 014CE485-008-Q48
      Status 100 = ON
      Value 100 = "100%"
      String
      Dimmable False
      Interface Z-Wave
      Device Type Internal Plug-In API, Type: Plug-In Type 0, SubType:
      Batterij
      Misc Settings Show Values
      Relationship Status Child
      Associated Devices 8 gang Sensor gang root
      Regards, Henk
        Hi Steve,
        Reference ID 210
        Status 0 = OFF
        Value 0
        String No Status
        Dimmable False
        Interface Z-Wave
        Reference ID 211
        Status 100 = ON
        Value 100 = "100%"
        String
        Dimmable False
        Interface Z-Wave
        Batterij
        Regards, Henk
        OK, I see the problem.
        The Device Type (String) for the battery child is named Batterij, which is presumably Battery in Dutch. I haven't come across HS using different languages with the device type, or did you edit the device types?
        The plug-in searches for 'battery' within the device type which is why it is not finding your battery devices. I will try and post an update tomorrow that will pick up your battery devices.
        Steve
          Thanks Steve for your update. This makes sense. I created Dutch named device types and this causes the mixup.
          If needed I can also change all the strings to Battery instead of Batterij.
          Regards and thanks again for this very nice plugin.
          Henk
            Henk
