Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Z-Wave Plug-in
HomeSeer Z-Wave Plug-in Discussions relating to the Z-Wave plug-in
Old April 17th, 2017, 10:57 PM
nibrt nibrt is offline
Viewer
Control 240v pool pump
I would like to control my pool pump which is 240v. Can I use the following device
http://www.homedepot.com/p/GE-40-Amp...2726/207059394
I searched everywhere and everybody is talking about an Intermatic control that was discontinued or using an ELK 9200 which is not rated for outdoor. My pump is inside a shed but water might enter the shed, so I would really like something rated outdoor. The manual for the GE switch says it can control 2 120v lines that power a 240v device.
Nio
Old April 18th, 2017, 09:18 AM
ewkearns's Avatar
ewkearns ewkearns is offline
Intermatic CA3750 is still available on Amazon....
HomeSeer Version: HS3 Pro Edition 3.0.0.398
Operating System: Microsoft Windows 10 Pro - Work Station
Enabled Plug-Ins:
  • 2.0.49.0: BLBackup
  • 2.0.22.0: BLUPS
  • 1.2.2.0: Device History
  • 3.7.0.0: Harmony Hub
  • 3.0.0.42 Easy Trigger
  • 3.0.1.90: PHLocation
  • 3.0.6331.36036: UltraCID3
  • 3.0.5917.35093: UltraLog3
  • 3.0.6554.33094: UltraMon3
  • 3.0.0.76: weatherXML
  • 3.0.1.162: Z-Wave
  • 3.0.51: HS Touch Designer
  • 3.0.0.40 Z-Seer+
Old April 18th, 2017, 09:22 AM
cheeryfool's Avatar
cheeryfool cheeryfool is offline
Super Seer
It's cheaper direct from HomeSeer
cheeryfool
Old April 18th, 2017, 10:05 AM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
I've been using a CA3750 (from HS) for a while now to control a pool pump and booster pump. It's under a shed, but exposed to the elements somewhat. It works fine.
62 Z-Wave Nodes, 162 Events, 293 Devices
Old April 18th, 2017, 10:08 AM
ewkearns's Avatar
Hmmmm... yes, they are. Last time I checked, the item didn't appear as available.
Old April 18th, 2017, 11:47 AM
racerfern racerfern is online now
How many amps is the pump motor?
Old April 18th, 2017, 12:02 PM
rmasonjr's Avatar
I dont recall off-hand, but it is a 1.5HP Hayward pump that is wired for 220V
https://www.amazon.com/Hayward-SP261...sr_1_1?ie=UTF8
Old April 20th, 2017, 08:02 AM
Google says a 1.5hp motor is 10 amps at 240v. I was thinking about the Qubino relay that is rated for exactly that. So there's no room for any load increase. Oh well.
Old April 20th, 2017, 08:18 AM
clafa clafa is offline
Hi, I am using 2 intermaric CA3750 and they work.
You need to be aware that these units can't be very far from other z-wave devices since they have their antenna inside the plastic case.
I installed a z-wave repeater close by (indoors) and have had zero issues.
One of these is for a 120v pump and the other is controlling the heat pump 220v and no issues.
Chris
S6-Pro, Zwave devices, 2 Kinects, iTunes DAAP, UltraGCIR, Vista Alarm, Sonos, Whole House Audio, Pool control using Spud's plug-in, HSTouch, BLRussound, BLLog.
Old June 12th, 2017, 10:11 PM
mskvarenina mskvarenina is offline
Seer Plus
Did you have any issues adding the CA3750 to your network? I can't get mine to pair but it came without any instructions so I was wondering if it's someone else's return and can't be disassociated...
Old June 12th, 2017, 11:05 PM
cheeryfool's Avatar
Super Seer
Use the HS3 remove node option before trying to include (pair) it
Old June 12th, 2017, 11:31 PM
Seer Plus
Just tried that. No change. Didn't think I could remove it from the network if it never was part of the network.
GE has a Z-Wave pool controller (model 12726) for twice the price that seems to have good reviews. Looks like I may end up with this model if I can't figure out how to reset the Intermatic...
Old June 13th, 2017, 12:04 AM
How I paired the device
Since these are high voltage units and typically far away from the z-net, I used a "extension" cord to power the unit with 120v and take it next to the z-net, then pair the device and then installed the unit in its final location. With 240v.
The manual can be found here
http://waterheatertimer.org/pdf/Inte...750-Manual.pdf
I learned how to connect the wires by looking at pictures see here
http://waterheatertimer.org/images/H...ic-CA3750.html
Hope it helps,
Chris
Old June 13th, 2017, 01:36 PM
Seer Plus
So that's a possibility
The controller is wirelsss so perhaps I'll bring it down to the timer and see if it will pair just feet away.
Then assuming that works perhaps it will remain on the network for commands.
Old June 14th, 2017, 12:12 AM
Seer Plus
Moving the HS controller right next to the CA3750 did the trick. Once paired to the network it talked to a number of nearby nodes so I was able to move the controller back to it's usual spot.
Old June 22nd, 2017, 11:32 AM
Seer Plus
So it seems I've been bitten but the same bug others have reported. The CA3750 looses it's Z-Wave pairing with the controller for no apparent reason.
When I did a full optimization of the network, the node was not seen by any neighbors and when it reached that node it was it was not found on the network.
I guess I can bring the controller back down and re-pair it but my suspicion is, this is simply a flaw in the timer that is not going to be addressed/fixed since it's my understanding Leviton has discontinued this product and most likely isn't offering any support for it such as a firmware update that may address it dropping off the network.
Looks like I may end up with the more expensive GE model afterall.
Anyone else have any insight on this topic?
Old June 22nd, 2017, 01:09 PM
rmasonjr's Avatar
This weekend, I'm swapping my CA3750 out for the Heavy Duty Smart Switch.
Old June 22nd, 2017, 07:36 PM
Seer Plus
That's a great idea. That switch is about $90 compared to the GE at $150
Do you know if one can secure Romex wire to it?
Old June 22nd, 2017, 08:03 PM
rmasonjr's Avatar
Yes you can
Old June 25th, 2017, 02:21 PM
Seer Plus
Hooked mine up this weekend. So far so good. Definitely a little less commercial looking compared to the typical plastic or metal timer cases but I'm sure it will do the job just fine. I have a few other Aeotec devices and all work perfectly 100% of the time.
Take note of the wiring for a 120v circuit. The website has wiring diagrams that show different scenarios. It's different than what you would think just by reading the markings on the switch.
Pool Pump Control tulit HomeSeer Z-Wave Plug-in 4 June 23rd, 2011 03:16 PM
Pool pump control using a SwitchLinc 220V Relay leerogers Insteon Plug-in (Mark Sandler) 24 April 22nd, 2011 09:10 PM
Suggestions on how to control a pool filtration pump pyspilf HomeSeer General Discussion Area 2 May 29th, 2008 03:18 AM
Pool Pump Control & Timing anogee General Home Automation Hardware Discussion 1 May 27th, 2005 06:41 AM
Pool Pump Control Thickman HomeSeer General Discussion Area 6 July 22nd, 2004 07:12 PM
