Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 / HS3PRO Discussion
HS3 / HS3PRO Discussion Discussions related to the released version of HS3/HS3PRO
Old April 18th, 2017, 02:41 PM
wmark wmark is offline
Angry Reset password
How do I reset the password and user id in HS3. I am somehow locked out of my system. Just did a reinstall and am locked out of setup. I somehow no longer and administrator. Do I need to call support.
HomeSeer Version: HS3 Pro Edition 3.0.0.208
Operating System: Microsoft Windows 10 Pro - Work Station
Number of Devices: 319
Number of Events: 106
Enabled Plug-Ins
2.0.27.0: BLDenon
2.0.25.0: BLLAN
2.0.6.0: BLPlugins
2.0.111.0: BLRadar
2.0.83.0: BLRF
1.0.3.0: BLShutdown
2.0.40.0: BLSpeech
3.0.0.21: EasyTrigger
3.0.0.91: HSTouch Server
3.0.5857.37252: UltraGCIR3
3.0.0.40: weatherXML
3.0.0.36: X10
3.0.1.54: Z-Wave
Old April 18th, 2017, 02:49 PM
rmasonjr's Avatar
rmasonjr rmasonjr is online now
I think you can rename/remove the users.cfg file and start up HS and that should work. Maybe others can chime in if that works or not...
Old April 18th, 2017, 03:33 PM
concordseer concordseer is offline
I'd imagine you could copy a vanilla user file over the current user file and be back up and running using the default user name and password. Just make a copy of your HS3 folder and rename the copy and you could give it a try.
Old April 18th, 2017, 04:03 PM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
You are not the first - nor the last - to encounter this problem. Here's a link to a post from 2006.
https://board.homeseer.com/showpost....06&postcount=4
HS3 Pro Edition 3.0.0.435
HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | Green-Eye | X10:
Compose, XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3
Old April 18th, 2017, 04:23 PM
Smile Solved
Thanks guys. Deleting the cfg file took care of it.
Old April 18th, 2017, 09:04 PM
Kerat Kerat is offline
This is good to know
Reset Password mulu HomeSeer General Discussion Area 3 February 13th, 2017 08:45 AM
Problem with Password reset srodgers MyHS Remote Access Service 1 May 9th, 2015 09:55 PM
How to reset web server password? jimcu HomeSeer General Discussion Area 6 May 22nd, 2010 07:45 PM
How do you reset the HSS2 password Maui10312 HS2 / HSPRO 2 April 9th, 2009 11:00 PM
