Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 / HS3PRO Discussion
HS3 / HS3PRO Discussion Discussions related to the released version of HS3/HS3PRO
Old April 19th, 2017, 11:08 AM
wcross wcross is offline
CAPI to set value AND status
I'm trying to set a device value and status via CAPI. I have been successful with setting a value as such:
http://MyHS/JSON?request=controldevi...=100&value=100
However, I cannot figure out (and yes, I've read the CAPI docs) how to set the status string and would appreciate some help.
IDEALLY, I'd like to do it in a single call to set both value and status. Possible?
Old April 19th, 2017, 11:29 AM
rmasonjr's Avatar
rmasonjr rmasonjr is online now
You might see if this helps:
https://board.homeseer.com/showpost....7&postcount=30
Old April 19th, 2017, 01:28 PM
Thank you, but unfortunately the example to set the status string fails:
http://IP/JSON?request=setdeviceproperty&ref=####&property=NewDevStrin g&value="Some Status String"
with error:
{ "Response":"Error, controlling device" }
Old April 19th, 2017, 07:38 PM
mwolter mwolter is offline
This is the command I run on my Mac. Your results many vary.
curl "http://HSIP/JSON?request=setdeviceproperty&ref=390&property=NewDevString &value=test" -k
Note: no space between String and &
Old April 19th, 2017, 09:43 PM
Thank you, that worked! I don't suppose there is a means to set the device value and string in the same CAPI call?
I'm trying to use this with the HA-Bridge software to set HS device value and string based on two parameters, but can only enter a single GET statement.
Old May 10th, 2017, 09:33 AM
Anyone? I'm trying to integrate a couple third-party products with HomeSeer, but each only allows a single web call. It appears from what I can see that CAPI only allows setting a device value OR string per call, but I really have a need to set both in a single call.
Old May 10th, 2017, 04:58 PM
mrhappy mrhappy is offline
HS3 tried to get away from this as a concept, the string (which is now the status) should be set from the value and not independent of each other unless you are storing images or complex objects such as charts in the string. HS2 you could end up with one device having a different string, a different value and a different status all independent of each other! Are you confident you need to set the string?
Status/modifying timer CAPI Findus HS3 Scripting 3 August 17th, 2016 11:14 AM
CAPI Gallina HS3Touch™ 3 March 15th, 2016 10:23 AM
OK Capi!!! Help Gogs HS3 Scripting 35 April 24th, 2015 05:11 PM
CAPI? MrSkippy HS3 Scripting 2 April 4th, 2014 06:54 AM
Help with CAPI please naellis HS3 Scripting 4 March 26th, 2014 09:03 AM
