Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Z-Wave Plug-in
HomeSeer Z-Wave Plug-in Discussions relating to the Z-Wave plug-in
Old April 20th, 2017, 08:06 AM
grahamk grahamk is offline
Accidental removal of node
I deleted the root of a couple of devices and shouldn't have because it deleted all thier children too. Oops. Is there a way to get these devices back other than including them again?
Reason I ask is that one device was node 23, when i re-added it i noticed in the log that it was added as node 75, but the system went through a string of log messages to remove node 23 first - so despite it being deleted it's information seemed to still be in the system. Is there a way to get that info back for other nodes i deleted, or is including them again the way to go?
Old April 20th, 2017, 08:41 AM
rprade's Avatar
rprade rprade is online now
If you only deleted the nodes from the Device Manager, they are still in the controller. Go to Plug-ins>Z-Wave>Controller Management then choose the Action "Import Node Info from Controller and Scan Devices". That will re-create the deleted root and child nodes in the Device Manager. They will be created with generic names and locations. It will not affect existing and working nodes. This will not work on any that you have attempted to include again, because the old node is excluded when you try to include it again. When they are imported again, they will have the same root node number, but all of the Reference IDs will be different. As a result all of the events associated with the nodes you deleted will have to be fixed.
Randy Prade
Aurora, CO
Prades.net
Old April 24th, 2017, 10:32 AM
Thanks Randy - that worked! :-)
Failed to get basic node information from new node renevk HomeSeer Z-Wave Plug-in 4 October 23rd, 2014 10:28 AM
Failed to get basic node information from new node kenflorian HomeSeer Z-Wave Plug-in 0 July 27th, 2012 05:40 PM
awake monitor accidental click pcca-matrix HSTouch™ 1 April 27th, 2011 07:41 AM
accidental setup incomplete inhibit bunkers mcsSprinklers 3 August 19th, 2007 05:03 PM
Node removal status: Failed, node may still exist kenflorian HomeSeer Z-Wave Plug-in 5 May 9th, 2007 08:46 AM
