Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old April 20th, 2017, 10:50 AM
MarkSeer MarkSeer is offline
Unhappy Insteon devices lost after HS upgrade, events broken
After upgrading from HS 3.0.0.298 to 3.0.0318 all Insteon devices were gone. I followed the instructions in another post and restored the entire contents of the insteon.ini file from the bottom of the insteon error report log file in the pre-upgrade backup and this restored all of the devices. The problem is that none of the events that involve an Insteon device work and the events page shows (select a device) everywhere there was a device. I have a lot of complex events so going through each one would be a royal pain in the you know what...
Is there a way to restore these easily? The backup I have is from when I was on the old version, so if I restore homeseer to that previous version backup, would there be some sort of a config mismatch? If not, could you please direct me to instructions on how to restore these events from backup while messing up a little other stuff as possible?
Mark
Old April 20th, 2017, 12:38 PM
mnsandler's Avatar
Insteon Overlord
i'll have to speak with HST on this issue.
You need to restore an insteon.ini and homeseer database together.
I think you can restore an older homeseer db and the newer app will upgrade it as necessary
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old April 20th, 2017, 01:28 PM
Thanks.. Do I need to post this to a different part of the forum, or will you follow up?
Old April 20th, 2017, 01:30 PM
mnsandler's Avatar
Insteon Overlord
you might ask elsewhere about restoring an older db to .318, but otherwise I can help you get your insteon devices back
Old April 22nd, 2017, 12:27 PM
The devices are back. The issue now is that the events that involve the insteon devices no longer reference them. How is this rectified without rebuilding all of them?
Old April 22nd, 2017, 02:06 PM
mnsandler's Avatar
Insteon Overlord
you must restore a good insteon.ini and homeseer database from the same backup timeframe
Old May 5th, 2017, 05:42 PM
tomstechnic tomstechnic is offline
I'm seeing the same problem. I restore from a previous backup, but once I update the Interface port for insteon, and restart, all of my devices disappear.
Insteon plugin version 3.0.6.0
HS3 v3.0.0.318
Old May 5th, 2017, 07:28 PM
mnsandler's Avatar
Insteon Overlord
HS3 v3.0.0.318
please restore an Insteon.ini and corresponding HS database
This problem is with HS. It's shuting down and not closing the ini properly
Old August 2nd, 2017, 11:36 AM
Quebec911 Quebec911 is offline
Lost insteon.ini after HS3 Update
Hi Guys,
Same thing on my system after updating my Zee2, lost the basic config and all devices. The event were there, but broken (device less). All the z-wave was working perfectly (device and event). I finally recreated an .ini file from a cut and paste of an old insteon error report. Still have to reassign the devices in the event but that is only an annoyance.
Francois
Old August 2nd, 2017, 12:49 PM
mnsandler's Avatar
Insteon Overlord
did you try restoring a previous homeseer hsd file, and insteon.ini
Old September 7th, 2017, 10:42 AM
mnsandler's Avatar
Insteon Overlord
All,
I've posted a new version in the beta section of the Updater that should help with the original issue here: losing the insteon.ini
HTML code is On
Lost all Insteon devices independentpete Insteon Plug-in (Mark Sandler) 47 September 14th, 2017 10:14 AM
all devices and events get lost scheder@ga.com HS3 / HS3PRO Discussion 12 July 3rd, 2016 01:15 PM
Help! Lost all my INSTEON devices Seer1001 ISY Plug-in Beta (3P) 15 May 28th, 2012 07:09 PM
Lost all of my devices, events, etc pcgeek HS2 / HSPRO 11 September 12th, 2008 09:25 PM
Insteon Devices Lost dona Insteon Plug-in (Mark Sandler) 2 January 15th, 2008 06:49 AM
