Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeSeer Wall Dimmers & Switches
HomeSeer Wall Dimmers & Switches Forum for HomeSeer Wall Dimmers & Switches
Old April 20th, 2017, 05:17 PM
vlad vlad is offline
Viewer
using WD100 dimmer with non-dim-able light fixture
I bought a bunch of WD100 dimmers but it turned out a lot of the LED light fixtures we received runs on a non-dimable LED ballast. It looks to me like a switchable power supply.
Is it safe to use dimmer in this case? I'm specifically concerned about slow transitions from on to off states, when switchable PSU would try to compensate drop in voltage (if it's voltage-driven dim) by drawing more amps and burning out WD100.
Satellite question - is it possible to configure dimmers via zware to disable those transitions completely, so it's instant on/off - manual or remote control. I was not able to find tech docs for WD100's zwave commands.
p.s. I'm using Home Assistant.
Thank you.
Old April 20th, 2017, 07:43 PM
jvolkman jvolkman is offline
Yes, you can specify different ramp rates (including effectively instant) for both local and remote control.
This page has a summary of configuration parameters: http://www.cd-jackson.com/index.php/...icesummary/346
Old April 22nd, 2017, 05:25 PM
Viewer
thank you. I was able to set this up to (visually) instant on/off
HS-WD100+ Dimmer + Companion: What Functions? gtrguy HomeSeer Wall Dimmers & Switches 5 December 5th, 2016 10:13 PM
Hometroller Zee and HS-WD100+ Dimmer issues pi1 HomeSeer Wall Dimmers & Switches 3 October 22nd, 2016 04:41 PM
HS-WD100+ Homeseer Zwave dimmer Automated HomeSeer Wall Dimmers & Switches 12 May 13th, 2016 04:25 PM
Does the new HomeSeer HS-WD100+ dimmer have any properties? jumper4000 HomeSeer Wall Dimmers & Switches 1 April 19th, 2016 02:00 PM
2 micro switches in light fixture fischb22 HomeSeer Z-Wave Plug-in 7 March 2nd, 2014 02:40 AM
