Hi -
I was using the trial of BL Stat and thought it looked great. Was going to buy it when I got a thermostat. So, I just received a Honeywell WiFi thermostat as a gift. Hooked it up with the Honeywell Plugin. Seems to work great, but...
I know BLStat won't control it natively since it's not ZWave.
Will BLStat control it through the Honeywell plugin? This is, if both the Honeywell pluigin and BLStat are installed, will BLStat see the Honeywell as a Zwave thermostat?
If unsure, is it possible to reset my trial so I can test it?
Thanks either way...
Mike
Mike
