(500) Internal Server Error
    I get a variant of the following message pretty much every time I control something through the plugin. It usually still works, but not always. Any thoughts would be appreciated!
    ERROR in PlayURI for zoneplayer = Kitchen with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E585D787601400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://192.168.0.102:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://192.168.0.102:1400/MediaRende...nsport/Control and Request = 0 x-rincon:RINCON_000E585D787601400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 402 with error = The remote server returned an error: (500) Internal Server Error.
    Here's my system info:
    Current Date/Time: 3/17/2017 4:09:00 PM
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.313
    Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 0 Days 4 Hours 34 Minutes 38 Seconds
    IP Address: 192.168.0.107
    Number of Devices: 175
    Number of Events: 69
    Available Threads: 392
    Enabled Plug-Ins
    3.0.0.33: EnvisaLink
    3.0.0.68: HSTouch Server
    3.1.0.18: Sonos
    3.0.1.102: Z-Wave
    Enabled Plug-Ins
    3.1.0.18: Sonos
    3.0.1.102: Z-Wave
    How many players do you have? How are they connected? There are many postings here about network issues when you wire more than one player physically versus just one and let the Sonos wireless do the rest.
    Is this an error when you do announcements? Could you post your player table.
    Dirk
      Dirk
      Mine generates those same errors when ONE is connected to Ethernet and the rest are SonosNet. As soon as I revert to pure WiFi, the errors stop. I have gone back and forth and even tried a separate Sonos Boost. The errors are never there when pure WiFi, but are there when one device connected to Ethernet (doesn't matter which one), I get errors. The error is not with every announcement, but does happen at least once per day.
      The problems appear to be only in the plug-in and when they occur an announcement usually doesn't go to most or all of the clients. Using the Sonos App on iOS, Android or PC there is no difference in behavior between a Boost or WiFi topology.
      I've been purely on WiFi for a couple of months without seeing the error.
        OK, this makes sense. My playbar is plugged into ethernet, while the rest are on wifi. I might just leave it then, as otherwise it seems to be working ok...
        FWIW, here's my device table:
        Kitchen RINCON_000E585D787601400 True S5 192.168.0.102
        Bedroom RINCON_B8E937886FEC01400 True S1 192.168.0.104
        Bathroom RINCON_B8E9375C25F201400 True S1 192.168.0.103
        TV RINCON_000E58B7E88F01400 True S9 192.168.0.101
