How to use script methods
i want to track the power usage over last 7 days, so I made 7 virtual devices 9P1-P7), at midnight, I copy 6-77 5-6, etc. I then want to reset the accumulated value on ECM1240
I tried the following (assuming this works with the 1240):
I get this error:
424:Object required in line 10 More info: Object required
Can anyone tell me how to fix?
Regards
mark
Sub Main hs.setdevicestring "P7", hs.devicestring("P6") hs.setdevicestring "P6", hs.devicestring("P5") hs.setdevicestring "P5", hs.devicestring("P4") hs.setdevicestring "P4", hs.devicestring("P3") hs.setdevicestring "P3", hs.devicestring("P2") hs.setdevicestring "P2", hs.devicestring("P1") hs.setdevicestring "P1", hs.devicestring("]6") hs.plugin("BLPowerMonitor").ResetEcm1220AccumulatedData() End Sub
Regards
mark
