support multiple 1240's?
    Blade,
    Can you confirm if it will connect to multiples if using a single serial port? ultrajones plugin only supports 1 so I am either forced to sell them and get a greeneye or find a different plugin to go with.. please let me know..
    my goal is to get 1 or 2 more 1240's only as i have 2 now.. so it is cheaper in the long run to use 4 of them to monitor all of my stuff vs getting a greeneye...
    My ECM1240 uses a TCP connection to my router. The ECM Engine should control more than 1 1240. The plugin receives all info from the ECM Engine written by Brultech
    The ECM Engine app allows for 3 serial monitors and 2 TCP/IP monitors
    Cheers,
    Bob
      ok i have 2 x 1240's connected via 1 serial port..
      as seen here
      http://forums.homeseer.com/showpost....63&postcount=2
      but ultrajones is eluding to that i can use each one to a single serial port.. so have to look into that...
        I use the EtherPort Gateway and it works perfect. Connects into your router or switch
        Cheers,
        Bob
