Hello,
I am receiving the following error in my Homeseer log:
I'm running HS3 Standard Edition 3.0.0.208 on Windows 10, and the ISY is running firmware 4.3.26 and UI 4.3.26.
I also get exactly the same error when I run the old version of the plugin on HS2 (I test these separately, not at the same time).
Any idea what could be causing the problem?
Thanks in advance for any help.
Dec-23 12:38:31 PM ISYInsteon SendRequest : -> Using Authorization [Basic andzaG9tZTphcmNoZWQwNg==] Dec-23 12:38:31 PM ISYInsteon SendRequest : -> For command: [ ] Dec-23 12:38:31 PM ISYInsteon SendRequest : Failed to get response from ISY (The underlying connection was closed: The connection was closed unexpectedly.). Dec-23 12:20:31 PM ISYInsteon Restart : -> _0120 Dec-23 12:20:31 PM ISYInsteon Restart : Last message received before restart Dec-23 12:20:31 PM ISYInsteon Bottom of subscription thread loop Dec-23 12:20:31 PM ISYInsteon Attemp to close TcpClient Dec-23 12:20:31 PM ISYInsteon Read exited with False Dec-23 12:20:31 PM ISYInsteon read : The subscription connection to ISY has failed. Dec-23 12:18:51 PM ISYInsteon read : ISY subscription: No data for 120 seconds, network problem?. Dec-23 12:16:48 PM ISYInsteon read : ISY subscription: No data for 120 seconds, network problem?. Dec-23 12:14:45 PM ISYInsteon read : ISY subscription: No data for 120 seconds, network problem?. Dec-23 12:12:43 PM ISYInsteon read : ISY subscription: No data for 120 seconds, network problem?. Dec-23 12:10:55 PM Info System connected to MyHomeSeer Service successfully. Dec-23 12:10:55 PM Info System connected to MyHomeSeer Service, waiting for acknowledge... Dec-23 10:47:07 AM ISYInsteon SendRequest : -> Using Authorization [Basic andzaG9tZTphcmNoZWQwNg==] Dec-23 10:47:07 AM ISYInsteon SendRequest : -> For command: [ ] Dec-23 10:47:07 AM ISYInsteon SendRequest : Failed to get response from ISY (The underlying connection was closed: The connection was closed unexpectedly.).
