Is there any way to make the single tap on the HS switches NOT control the local load? What if I wanted to set up double-tap to control the local load and the single tap to only trigger the central scene stuff? Is this possible?
The use case I have in mind is to have the single-tap control Philips Hue functionality, and then have the double-tap as back-up in case I need to actually turn off the local load. As it stands, I can't turn on the light and a) control the Philips Hue right away because it takes a couple seconds to report back to the hub that it's reachable once it recovers from power outage and b) when the power returns from turning on the local load, the Philips Hue turns on at full brightness, which at some times is not desirable. I'd like to set up the single-tap to mimic local control via JowieHue actions and have the double-tap actually control the local load instead.
