Stick Up Camera
    Stick Up Camera
    Is anyone using one of the Ring Stick Up camera with this plug-in? I can't get mine to work.
    My ring stick up does not show up on my plugin. The Ring doorbell and associated chimes do though.
      Are you saying that you have a Stick Up Camera and the plug-in does not trigger with motion from the Stick Up Camera?
        I need someone to turn on debug logging in the plugin and capture the data coming from the stick up camera. Leave the debug log on for 1 minute and then turn it off and attach the BLRing-Detailed.log file zipped so I can see what is happening
        Cheers,
        Bob
          Here you go.. I obfuscated a few things...not sure if I should or not...let me know if it causes you a problem..
          After I started the debug logging, I triggered the camera to sense motion and I got the notification on my phones.
          Let me know if you need me to do something else. I will be away for a while so there may be some gaps in my responses after this.
          04/27/2017 08:08:24:083 AM : v2.0.12.0 - **************** Debug Logging ENABLED at 4/27/2017 8:08:24 AM ****************
          04/27/2017 08:08:24:086 AM : v2.0.12.0 - EnableDebugLogging() finished
          04/27/2017 08:08:24:086 AM : v2.0.12.0 - WebPageOptions.postBackProc() finished
          04/27/2017 08:08:58:263 AM : v2.0.12.0 - Check_Rings() started
          04/27/2017 08:08:58:263 AM : v2.0.12.0 - Request_Ring_History() started
          04/27/2017 08:08:58:263 AM : v2.0.12.0 - Request_Ring_History(): ringHistoryCount --> 25
          04/27/2017 08:08:58:263 AM : v2.0.12.0 - Request_Ring_History(): baseUrl --> https://api.ring.com
          04/27/2017 08:08:58:263 AM : v2.0.12.0 - Request_Ring_History(): locationUrl --> /clients_api/doorbots/history?api_version=9&auth_token=K2xZ-UEg_jnLYQayyyyy&limit=25
          04/27/2017 08:08:58:393 AM : v2.0.12.0 - Request_Ring_History(): thePageContents --> []
          04/27/2017 08:08:58:393 AM : v2.0.12.0 - Request_Ring_History() finished
          04/27/2017 08:08:58:393 AM : v2.0.12.0 - Check_Rings(): myRing.History.Count --> 0
          04/27/2017 08:08:58:403 AM : v2.0.12.0 - Check_Rings(): myRing.ToString -->
          Ring:
          Profile:
          email: 1234@gmail.com
          first_name:
          last_name:
          phone_number:
          authentication_token:yes there is one
          Features:
          remote_logging_format_storing: False
          remote_logging_level: 1
          subscriptions_enabled: True
          stickupcam_setup_enabled: True
          vod_enabled: False
          nw_enabled: True
          nw_user_activated: False
          ringplus_enabled: True
          lpd_enabled: True
          reactive_snoozing_enabled: False
          proactive_snoozing_enabled: False
          owner_proactive_snoozing_enabled: True
          live_view_settings_enabled: True
          delete_all_settings_enabled: False
          power_cable_enabled: False
          device_health_alerts_enabled: True
          chime_pro_enabled: True
          multiple_calls_enabled: True
          ujet_enabled: False
          multiple_delete_enabled: True
          delete_all_enabled: True
          lpd_motion_announcement_enabled: False
          starred_events_enabled: True
          chime_dnd_enabled: False
          video_search_enabled: False
          floodlight_cam_enabled: True
          04/27/2017 08:08:58:403 AM : v2.0.12.0 - Check_Rings() finished
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - PostBackProc(): thePageName --> BLRingOptions
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - PostBackProc(): data --> chkDebugLogging=unchecked&id=chkDebugLogging
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - PostBackProc(): user --> default
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - PostBackProc(): userRights --> 6
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc() started
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc(): page --> BLRingOptions
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc(): data --> chkDebugLogging=unchecked&id=chkDebugLogging
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc(): user --> default
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc(): userRights --> 6
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc(): parts.Count --> 2
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc(): parts: key --> chkDebugLogging; value --> unchecked
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc(): parts: key --> id; value --> chkDebugLogging
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc(): id --> chkDebugLogging
          04/27/2017 08:09:56:131 AM : v2.0.12.0 - WebPageOptions.postBackProc(): value --> unchecked
          04/27/2017 08:09:56:141 AM : v2.0.12.0 - DisableDebugLogging() started
          04/27/2017 08:09:56:141 AM : v2.0.12.0 - **************** Debug Logging DISABLED at 4/27/2017 8:09:56 AM ****************
            That does not give me what I need so try this:
            1. Delete debug log
            2. Disable plugin
            3. Edit hspi_BLRing.ini and change debugLevel=true and save INI file
            4. Re-enable plugin
            5. After plugin started for a minute then turn off debug logging and attach the entire log zipped
            Cheers,
            Bob
              OK, zip file attached.
                I do not see any devices for you
                04/27/2017 01:01:24:042 PM : v2.0.12.0 - Request_Ring_Devices(): thePageContents --> {"doorbots":[],"authorized_doorbots":[],"chimes":[],"stickup_cams":[]}
                Are you sure you are getting an auth token?
                Cheers,
                Bob
                  I saw that in the log. I've wondered about that because of what I see in the event. The event has a drop down box which I assume is to select the device, but there is no device to select.
                  I am getting a token. I don't know if there is a security risk for showing it which is why a didn't in the log.
                  It's 20 character string. Here it is with some of it obfuscated: K2xZ-yyy_jnzzzaUN51K
                  Both my cell phone and my wife's cell phone are getting the notifications. I tried using the Ring user email and password that I used to set up my Ring app on my cell phone in the Plug-in and it wasn't working so, I created a shared user in the same way I did for my wife's cell phone. I set up the shared user using the Ring app on my cell phone. I don't think there is another way other than that to set up another user.
                  I ran the Initialization again on the options page and repeated the sequence to produce the detailed log again and got this in the log:
                  04/27/2017 04:55:01:942 PM : v2.0.12.0 - Get_Ring_Devices() started
                  04/27/2017 04:55:01:944 PM : v2.0.12.0 - Request_Ring_Devices() started
                  04/27/2017 04:55:01:944 PM : v2.0.12.0 - Request_Ring_Devices(): baseUrl --> https://api.ring.com
                  04/27/2017 04:55:01:944 PM : v2.0.12.0 - Request_Ring_Devices(): locationUrl --> /clients_api/ring_devices?api_version=9&auth_token=Anrzhc2H56zFYwccXhtW
                  04/27/2017 04:55:02:116 PM : v2.0.12.0 - Request_Ring_Devices(): thePageContents --> {"doorbots":[],"authorized_doorbots":[],"chimes":[],"stickup_cams":[{"id":2474510,"description":"Front","device_id":"6064059b3e4 f","time_zone":"America/Los_Angeles","subscribed":true,"subscribed_motions":true,"ba ttery_life":"48","external_connection":false,"firmware_versi on":"cam-1.7.129","kind":"stickup_cam_v3","latitude":466666,"longitud e":-66666,"address":"yyyyyyyyy Gig Harbor, WA 98335, USA","settings":{"enable_vod":1,"exposure_control":2,"motion _zones":[0,1,1,1,0],"motion_snooze_preset_profile":"low","motion_snooze_presets ":["none","low","medium","high"],"live_view_preset_profile":"highest","live_view_presets" :["low","middle","high","highest"],"pir_sensitivity_1":5,"vod_suspended":0,"doorbell_volume":8 ,"vod_status":"enabled"},"features":{"motions_enabled":true, "show_recordings":true,"show_vod_settings":true},"owned":fal se,"alerts":{"connection":"online"},"motion_snooze":null,"ow ner":{"id":2071997,"first_name":"yyyy","last_name":"zzzz","e mail":"hgyru@comcast.net"}}]}
                  04/27/2017 04:55:02:123 PM : v2.0.12.0 - Request_Ring_Devices(): theResponseDevices.ToString -->
                  JSONResponseDevices:
                  04/27/2017 04:55:02:123 PM : v2.0.12.0 - Request_Ring_Devices() finished
                  04/27/2017 04:55:02:123 PM : v2.0.12.0 - Get_Ring_Devices() finished
                  04/27/2017 04:55:02:124 PM : v2.0.12.0 - InitializeService.Initialize_Ring() finished
                  04/27/2017 04:55:03:639 PM : v2.0.12.0 - Homeseer_Started_Check(): homeseer started Thread has finished!
                  04/27/2017 04:55:03:639 PM : v2.0.12.0 - Homeseer_Started_Check() finished
                  Now it looks like it sees the stick up camera but it still fails to trigger the event and the drop down in the event does not show the device.
                    Try out 2.0.13
                    Cheers,
                    Bob
                      I disabled 2.0.12 and then downloaded and installed 2.0.13
                      I still don't see the device "Front" in the DoorBot/Stick Up Cam drop down in the event. (should it show here??) All I see is "not set".
                      The event still does not trigger.
                      I did a restart with HS3 and then triggered the Stick Up Camera and got the notification on the cell phone but the HS3 event did not trigger. Nothing in the HS3 log.
                      I deleted my event and recreated it.
                      I then ran the Initialize routine and then triggered the Camera again with the same result.
                      Detailed log is attached.
                        Try 2.0.14 and let me know
                        Cheers,
                        Bob
                          It's working now. Thank you.
                          The device now shows up in the drop down box in the event.
                          My cell phone is notified about 2 secs after opening the front door and stepping out on the porch. With the plug-in settings set a 25 records and 60 sec polling it takes a few minutes before the event is triggered. With it set to 1 and 1 it takes about 32 secs to trigger the event.
                          Would it be possible to reduce the time to trigger an event? Is there a way to capture the motion on the local network from the camera?
                          I don't see where the records are stored on the HS server so I assume that the polling period sets the time when all of the last x records are downloaded and the plug-in looks at them to find one that shows motion and that causes the event to trigger. The records are then deleted. I guess the 32 second time to trigger must all be in the Ring server and Internet time to process and transmit the data. It would seem that a user would want to trigger the event only on the most recent motion event. Why download multiple records? Why is that it is almost instant to the cell phone but 32 secs to trigger the HS event?
                            Incomplete IF statement
                            There's a small nit that you may want to fix next time you are working on the code for this plug-in.
                            After setting up an event to detect motion the event shows the following:
                            IF BLRing: Motion for (see attached example)
                            I imagine you meant to put the name of the Ring device after the word for. It's working just fine though.
                            It would be nice if it was faster. (see my previous post)
                            Thanks for putting this one together.
                              Having sort of the same issue with 2.0.17.0
                              My first post, hello everybody.
                              This thread seems to be the closest to my problem that I can find.
                              In the log it seems that it initializes and get a token but can't read a json file for the device. It also seems to fail authentication on a page as well. Strange because it gets all the account information (I took out the information to protect the innocent) and gets the history but nothing shows in the Activity tab and my event never triggers.
                              If you could have a look at the log and maybe help Blade I would be grateful.
                              Mark
