That is weird. I have both also here. Moved one onver from RaspBee to Conbee and check if battery was updated correctly. It came out as it should. Don't really know what is happening here.
I suppose both of you already tried restarting the plugin to see if it updates?
I will check a bit more on the code here, but if one of you both could send me a detailed log from the plugin that has been running for say 30 minutes could help me. Maybe there is some issue to be found there?
Send it to w dot vuyk at upcmail dot nl. I am out for the weekend, so it will taka some time before I respond
Wim
Wim
