Design a Home
    Design a Home
    Hi, I'm totally New to this software And I need to do full design for one house. I tried on Youtube I didn't get much videos about designs and things. Can someone please point me for basic things?
    Design for home (3-4 rooms)
    Thank You
    You should start by asking yourself what your goals are. What do you want the system to do?
    Once you have a goal/problem. look at the technology and see what fits/provides a solution.
    In my case I'm a tinkerer. I looked around and decided I liked the aesthetics of zwave switches. I liked that there were a lot of zwave products from a large number of vendors. I bought a couple of switches, installed them, and gained a measure of comfort with the technology. I then set up a roadmap for expanding my system based on my ultimate goals. I wanted a guest to be able to walk in and use the system with little to no coaching. I prefer hard wired devices. I prefer local processing vs cloud based. I wanted my system to respond to alarm panel inputs as well as room occupancy. I wanted an integrated home audio system. I wanted to be able to remotely monitor and control heating/cooling/security/lighting. I also want my wiring to make sense and be able to swap a smart switch for a dumb one and have the load work as expected.
    If you're not sure what your goals are you could browse the forums for inspiration; look at what other folks have asked for help on. Browse the homeseer store and see if you discover a device that fills a need you never knew you had.
    Number of Devices: 1005
    Number of Events: 293
      Thanks for the reply
