Is there a way to manualy change the temp setting from the GUI. or do i have to use the WEB Page for that...
RC-80 Plugin Change temp from GUI.
aboyceTags: None
sbessel
Do you have devices set for each setpoint? if so then you can right click on those select the control option and then set the temp (or up/down).
Otherwise you are heading to the web page...
wegienka
To expand on what Scott has said, if you define a device for a Heat Set Point or a Cool Set Point, the plug-in will define Up and Down buttons that will take the temperature up or down by one degree. You can also use the DeviceValuesAdd script statement to add a drop down list of temperature values. Something like
hs.DeviceValuesAdd "S1","60"&chr(2)&"60"&chr(1&_
"61"&chr(2)&"61"&chr(1)&_
"62"&chr(2)&"62"&chr(1)&_
"63"&chr(2)&"63"&chr(1)&_
"64"&chr(2)&"64"&chr(1)&_
"65"&chr(2)&"65"&chr(1)&_
"66"&chr(2)&"66"&chr(1)&_
"67"&chr(2)&"67"&chr(1)&_
"68"&chr(2)&"68"&chr(1)&_
"69"&chr(2)&"69"&chr(1)&_
"70"&chr(2)&"70"&chr(1)&_
"71"&chr(2)&"71"&chr(1)&_
"72"&chr(2)&"72"&chr(1)&_
"73"&chr(2)&"73"&chr(1)&_
"74"&chr(2)&"74"&chr(1)&_
"75"&chr(2)&"75"&chr(1)&_
"76"&chr(2)&"76"&chr(1)&_
"77"&chr(2)&"77"&chr(1)&_
"78"&chr(2)&"78"&chr(1)&_
"79"&chr(2)&"79"&chr(1)&_
"80"&chr(2)&"80"&chr(1)&_
"81"&chr(2)&"81"&chr(1)&_
"82"&chr(2)&"82"&chr(1)&_
"83"&chr(2)&"83"&chr(1)&_
"84"&chr(2)&"84"&chr(1)&_
"85"&chr(2)&"85"&chr(1)&_
"86"&chr(2)&"66"&chr(1)&_
"87"&chr(2)&"87"&chr(1)&_
"88"&chr(2)&"88"&chr(1)&_
"89"&chr(2)&"89"&chr(1)&_
"90"&chr(2)&"90"&chr(1)&_
"Any Value"&chr(2)&"999", TRUE
Where S1 is the HSP or CSP device. You need to do this once.
Alan
