Comparison of MNSandler vs Homeseer Insteon plugin
    All,
    attached is a comparison I put together.
    Please reply with corrections and other updates and I will update the document
    Mark
    HS3 Pro 4.2.19.5
    Ha, the device support from the Homeseer plugin is laughable. They should just scrap it and pay you to include your plugin.
      OK one liner, the PDF is great!
      If I understand that right I can use the hub its then implied via local access, you mean the local LAN access I assume.
      So if I buy your plugin along with a standard Insteon hub then from HS I can control the Insteon devices.
      Sorry to be a pain, just want to get this right!
        Originally posted by mnsandler View Post
        All,
        Suggestion: also identify the supported Insteon hubs by their manufacturer number (2242-xxx, 2245-xxx, etc.)
          done
          Mark
          HS3 Pro 4.2.19.5
            that all looks correct.
            Mark
            HS3 Pro 4.2.19.5
              Does the MNSandler Insteon Plugin support the Insteon 2242 hub via LAN access?
              The document states that X10 devices are supported. I had thought that only the older 2242 hub supported X10 and that the newer Insteon 2245 hub had dropped X10 support.
                The plugin does support all Hubs via LAN access. And I believe you are correct that the 2245 does not support X10. I can update the document to clarify this. I'll test my 2245 first
                Mark
                HS3 Pro 4.2.19.5
                  I had read that it is possible to add X10 devices to the hub using the Android app, but not the iPhone app, for the newer hub.
                    I just tried my 2245-222 hub fw 9E and it *does* send and receive x10 cmds
                    Jan-03 4:41:33 PM Insteon Processing Received X10 Command: A All Units Off
                    Jan-03 4:41:33 PM Insteon Sending http://192.168.1.82:25105/1?XB=M=1
                    Jan-03 4:41:33 PM Insteon PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):60 80
                    Jan-03 4:44:22 PM Insteon ..Got Hub Response 02 63 62 80 06
                    Jan-03 4:44:22 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A to locate next possible STX
                    Jan-03 4:44:22 PM Insteon Clearing buffer...
                    Jan-03 4:44:22 PM Insteon ..My XML buffer begins with: 0263628006
                    Jan-03 4:44:22 PM Insteon Finished sending command.
                    Jan-03 4:44:22 PM Insteon Sending http://192.168.1.82:25105/3?02636280=I=3
                    Jan-03 4:44:22 PM Insteon Sending command 02 63 62 80 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                    my guess is smarthome dropped x10 support in their app, not the physical device.
                    Mark
                    HS3 Pro 4.2.19.5
                      Insteon Sandler plug in for HS3 no longer working
                      I use LAN connection to the Insteon Hub II ... looks like they are now using https and refusing connection on http.
                      Are others experiencing the same issue, or is it something with my config?
                      Quintin
                        Quintin
                        You may want to check out this post... https://forums.homeseer.com/showthread.php?t=196335
                        A update from Smarthome basically rendered the Insteon hub useless to everyone using Mark's Insteon plugin... I would suspect that the same is true for HomeSeers Insteon plugin.
                        You may want to verify your hub version and revert back.
                        Billy
                          Quintin
                          see post #146 in this thread for a solution
                          https://forums.homeseer.com/showpost...&postcount=146
                          Mark
                          HS3 Pro 4.2.19.5
