I have just installed a new Aeotec Get 5 Home Energy Meter. It seemed to install OK and I used Z-Tool to associate it with Homeseer 3 Pro but I cannot see any readings.
It responds when clicking on the device settings and it says, in the Z-Wave tab, that it is associated with HomeSeer Group 1 on the bottom.
If I click the VIEW-->Energy menu selection I do not see that device available.
If I click the VIEW-->Device Management I see the device listed but just one line with a grayed out circle 1/0 On/Off indicator showing Off.
I have checked the settings under the Z-Wave tab for Meter (A), Clamp 2, etc.
The various "Automatic report rate" values seem OK.
If I go to PLUG-INS-->Z-Wave-->Node-Information I can see the node but it says:
Controlled: Device Reset Locally
Supported: Zwaveplus Info, Version, Manufacturer Specific, Meter, Crc 16 Encap, Multi Channel, Configuration, Association Grp Info, Association, Firmware Update Md, Powerlevel, Security
Do I need any particular plugin?
