Help please, stuck on linux
    Hello
    I have an entire system setup, tried changing the ip to static and after reboot I did not get an answer from the zee s2
    So I took a monitor and pluged it in and I got the following:
    it is booting in linux there is a warning
    Image attached
    What do I do to get it back working?
    Your /etc/network/interfaces file is corrupt. Did you recently changed it?
    Sent from my SCH-R970X using Tapatalk
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      yes
      I tried setting up the static IP
        Yeah, looks like line 11 is bad. Does the login prompt eventually appear? Note that you won't be able to SSH to it remotely.
          there is a login prompt PRIOR
          but I don't know what to do.
          Don't know the user and pass
          Dont know how to fix the line that is corrupt
            Personally I would reimage the Zee-2 downloading the image from here ===>
            HS3 for Raspberry Pi2
            I would recommend too to use a new microSD card. I have had one bad card to date.
