Hi Folks-
I just got my UPB 'starter kit' and installed one switch. It's not working properly.
The PIM is an SA, version 4.15. I'm running UPStart on the same computer as HS, which is controlling a large number of X-10 devices successfully from the same outlet the SA PIM is plugged in to.
I replaced one Lightolier X-10 dimmer switch with one SA US11-30 1000W Single Dimming Transceiver. The location is about 40 feet from the panel, and the PIM is about 30 feet from the panel.
The UPS switch properly controls the load, and enters setup mode.
It appears to me that communications are very poor. When I run the UPB diagnostics Signal and Noise meters, I get:
Noise Count per sample: 10
Total noise energy: 138
Average noise energy: 14
Noise level: Severe
When I run the 'add device' setup wizard in UPStart, I get many timeouts and retries. Sometimes it gets further than others but it has never successfully added this device. I increased the number of retries to 16, the max allowed. It typically shows noise at the switch at 0, signal at the PIM at 25, and signal at the switch at 15.
Attached is a sample log of 'details' for the add device wizard.
My X-10 switches, including the one at that location, are moderately reliable - and controled from the same location as the UPB switch.
I don't know what all these number indicate - any advice from a UPB expert would be appreciated.
Jerry
Noise level: Severe
Jerry
