Originally posted by stevewinick
View Post
regarding your events, you can just "disable" them from the event page.
regarding the multiple KPLs controlling separate modules...
i would suggest using the plugin to create cross-links between the kpl keys (as controllers) and the other kpls and modules (as responders). You will need to repeat this for each kpl key that you want to control the other devices/btns.
this way no matter which device you use from hs to turn on the circuit, all the other kpl keys will be turned on as well.
so basically, if A and B are KPL keys and C is the module then create the following set of cross-links
A to B
A to C
B to C
hope this helps
you can always delete the links if it doesn't work as expected.
