Originally posted by aldo
View Post
Insteon PLM hangs
Mark
HS3 Pro 4.2.19.5
Similas PLM randomly stops working
I have been following this thread, because I have a similar problem.
I have replaced my PLM, but same results. I have run the update addresses, no change.
If I unplug PLM from the AC it will restart and run for a while.
I am using a USB to Serial (which I have used for years) adapter, and have replaced that too.
Attached is my zipped log in "debug" mode. Also, my "steup" is in my sig line.
Thanks,Attached Files
Thanks,Mark
HS3 Pro 4.2.19.5
I was wondering if I was the only one with these issues. I'm not asking for a 100% system but close to 90% would be great. I would like to rely on HS to give me the right reading on the lights and other sensors but not even close. I'm spending money to buy filters, time to reset switches and I hope I'm not annoying this board with these questions.
I was able fix most of these problems by replacing the PLM and resetting all the devices that I have. Now I get close to 90%. Although I still have few minor issues that I would like to resolve.
I have an Infrared Wireless Access Point with 12 channels setup up. What these channels do? I setup it with the remote control, if I use via the remote, the lights are going on and off with good reading but HS does not read the status on the lights correctly.
What these channels should do, if I change the icon light nothing changes?
I have two old ICON switches, I try to reset them but using the manual from Smarthome does not work, any other suggestions.
I added a delay on the event for the bathroom fan, but I noticed that it creates an event delayed every 1 minute, is it a normal thing?
Synchronize HS buttons with the devices would be a great accomplishment.
Almost there.
Aldo
Originally posted by aldo View PostI was wondering if I was the only one with these issues. I'm not asking for a 100% system but close to 90% would be great. I would like to rely on HS to give me the right reading on the lights and other sensors but not even close. I'm spending money to buy filters, time to reset switches and I hope I'm not annoying this board with these questions.
Almost there.
Aldo
i can't comment on the IR WAP.
here is a screen shot of my fan shutoff event
you need to find the source of the noise if you still have comm stats @ 90%. Did you reset the stats after making all the changes? might be worth it.Mark
HS3 Pro 4.2.19.5
Originally posted by aldo View PostThank you Mark for the print screen, it worked.
I assumed the IR was part of your plugin, these channels were created when I added the device. Smarthome does not tell me much about these extra channels.
Aldo
http://www.smarthome.com/2411R/IRLin...nverter/p.aspx
if so, then yes, the plugin will create 12 devices one for each btn on the remoteMark
HS3 Pro 4.2.19.5
Originally posted by aldo View Postyes, you are correct. what each of these btn should do? As I mentioned, from HS I can see them and put them on or off but the switches do not change, how do I program them?
AldoMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View PostWhich plm model do you have? i'm guessing a 2413s. and what plugin version are you running?
Also, attached is a startup log after I shutdown HS.
If I unpluf the plm and reconnect AC it will run for a while. I can't determine what is causing it to quit transmitting.
Ant thoughts on this?
can you control lights from the hs status page?
what about if you turn a light on manually, does hs see the msg?Mark
HS3 Pro 4.2.19.5
Sonny,
does the led on the plm stop flashing as well?
that is, when you turn a light on/off manually, do you see the led on the plm flash?Mark
HS3 Pro 4.2.19.5
I have done some testing and observing (I should have done this before).
When the PLM "locks up" and stops transmitting/receiving the LED does not flash. Previously I have unplugged the PLM to restart it. This time I sent a command from a remotelinc (2440) and the PLM restarted. I watched the HS Events Window in debug mode and when the PLM locks up you can see the failed polling attempts, but when I sent the remotelinc signal the PLM started flashing again and I can see "received STK" information. I am not really sure what the sending and receiving should typically look like. When the PLM is working normally I have noticed that there is almost always traffic in the network. I have one of the repeaters in a spot where I can see it.
Hope this helps,
would you be willing to installed 1.4.2.x or whatever previous version you had installed prior to 1.5.x and let me know if you still have the same issues with the plm
we need to figure out if this is a sw or hw issue?Mark
HS3 Pro 4.2.19.5
