Yes. They all have activity with today's date.
Mysterious Shutdown
that's is great news.
So if you end up automating your vista alarm (which i highly recommend), i would suggest the serial version of the ad2usb. The ad2usb is avail with a usb connection but uses the same ftdi chipset drivers and can suffer from the same "usb disconnect" problem you experienced with the usb PLM.Mark
HS3 Pro 4.2.19.5
I think we have finally resolved this one. Yeh!
Time to automate the alarmMark
HS3 Pro 4.2.19.5
You might need to resubscribe to the thread....but probably not necessary anymore
No rush on the alarm stuffMark
HS3 Pro 4.2.19.5
yah. you can shut it down
execute from the control/immediate windowe
&hs.debugmode=0Mark
HS3 Pro 4.2.19.5
Happened Again - no explanation
6/17/2012 3:18:58 PM ~!~Shutdown~!~Application shutdown at 6/17/2012 3:18:58 PM
6/17/2012 3:18:58 PM ~!~Shutdown~!~Running shutdown script ...
6/17/2012 3:18:58 PM ~!~Shutdown~!~Shutdown Script Completed
6/17/2012 3:18:58 PM ~!~Shutdown~!~Removing Plug-in Links...
6/17/2012 3:18:58 PM ~!~Shutdown~!~Removing all Callbacks...
6/17/2012 3:18:58 PM ~!~Shutdown~!~Shutting down plug-ins ...
6/17/2012 3:18:58 PM ~!~Shutdown~!~Shutting down X10 plug-in.
6/17/2012 3:18:58 PM ~!~Shutdown~!~Shutting down all I-O/Generic plug-ins.
6/17/2012 3:18:58 PM ~!~Shutdown~!~Shutting down plug-in: Insteon
6/17/2012 3:19:07 PM ~!~Shutdown~!~Finished shutting down all I-O/Generic plug-ins.
6/17/2012 3:19:07 PM ~!~Shutdown~!~Shutting down database...
6/17/2012 3:19:08 PM ~!~Database~!~Processed: 100 devices...
6/17/2012 3:19:08 PM ~!~Database~!~Processed: 200 devices...
6/17/2012 3:19:08 PM ~!~Database~!~Finished: 258 devices, applying device changes to database...
6/17/2012 3:19:08 PM ~!~Database~!~Processed: 100 events...
6/17/2012 3:19:09 PM ~!~Database~!~Processed: 200 events...
6/17/2012 3:19:09 PM ~!~Database~!~Finished: 287 events, applying changes to the database...
6/17/2012 3:19:10 PM ~!~Database~!~Finished applying device changes to the database.
6/17/2012 3:19:10 PM ~!~Database~!~Updating Events
6/17/2012 3:19:11 PM ~!~Database~!~Updating Event Actions
6/17/2012 3:19:11 PM ~!~Database~!~Updating Event Conditions
6/17/2012 3:19:12 PM ~!~Database~!~Finished applying event changes to the database.
6/17/2012 3:19:12 PM ~!~Database~!~Finished applying TVTimer changes to the database.
6/17/2012 3:19:12 PM ~!~Shutdown~!~Saving device status ...
6/17/2012 3:19:12 PM ~!~Shutdown~!~Shutting down web server ...
6/17/2012 3:19:17 PM ~!~Web Server~!~Web Server stopped
6/17/2012 3:19:17 PM ~!~Shutdown~!~Shutting down email ...
6/17/2012 3:19:17 PM ~!~Shutdown~!~Shutting down threads ...
6/17/2012 3:19:18 PM ~!~Shutdown~!~-------------------------------------------------------------------
6/17/2012 3:19:18 PM ~!~Shutdown~!~ HomeSeer Successfully Shut Down Now
6/17/2012 3:55:54 PM ~!~Startup~!~
6/17/2012 3:55:54 PM ~!~Startup~!~*********************************************** *********************************
6/17/2012 3:55:54 PM ~!~Startup~!~ HomeSeer version 2.5.0.49 Starting Now (Standard Build)
6/17/2012 3:55:54 PM ~!~Startup~!~Using system's regional settings
seems like something triggered the shutdown vs HS just crashingMark
HS3 Pro 4.2.19.5
