So, I'm in the process of getting quotes for an irrigation system to be installed. One said I would need 7 zones for my size lawn/garden.
Once it is done and they have installed whatever controller they usually deploy, is it pretty easy to change the controller to one that supports home automation?
I assume that all the controllers are nothing more than timers that turn on/off relays that control which zones are operating so changing out the controller shouldn't be that big of a deal?
Please correct me if I'm wrong. I currently use an Insteon/HomeSeet setup. Should I take a look at the EZFlora controller?
If I want to use a rain sensor, how would I go about doing that?
Thanks in advance!
Thanks in advance!
