That fixed it. Just so you know, they broke HStouch as well. (that was the only other plugin I had installed)
HS3 Beta Insteon Plug-in v3.0
Insteon plugin
Work for me too
OS : Win7 Ultimate 32 bits
Software :
HS2 : No more used
HS3 3.0.0.13
HSTouch server, android client 1.0.0.44
Zwave : Aeon Labs Zstick USB Controler, 2 Siegenia CO2 Sensors, 12 Fibaro Wall Plug, 2 Everspring Flood sensors
Current Cost plugin
Insteon plugin : Hub, 15 On/off plugs, 3 Dimmer Plugs
RFXCOM (not yet working) : 6 Oregon Scientific temperature/humidity sensors
Scripts : Reading of Weather Display datas (self modified for HS3 from HS2 version)
-----------------------------------------------------------------------------------Last edited by edd056; July 22, 2013, 04:01 AM.
Mark,
Is the Insteon hub 2242-222 as a networked PLM supported (or will it evenutally be supported) in HS3?
I have a PLC, and need to get something (either the PLM or the Hub) to replace it, to move forward with HS3. The hub seems more forward-looking with the ability to fiddle with it via I/P, so if your plugin will support it, I will go that way.
Gayle Snedecor
the hub is supported now in hs2 and is supported in my beta hs3 plugin
i do not plan on dropping any current functionality in hs3Mark
HS3 Pro 4.2.19.5
Originally posted by xlucent View PostDoes the latest version of the plug-in support event actions or triggers? I'm holding off on installing HS3 until Insteon works with it since that's the primary interface I use with Homeseer.Mark
HS3 Pro 4.2.19.5
Please help me Mark! I am running 3.0.0.9 and HS3 3.0.0.17. Using Windows 7 64bit and still getting the **FATAL**: Failed getting InterfaceStatus from Insteon - the interface was not found in the list of active interfaces. I can't put in a com port # anywhere. What am I doing wrong? Here is my log:
Waiting for user to continue trial...
Starting up....
8/13/2013 6:19:14 AM ~!~Error~!~Initializing plug-in(1): Insteon Instance::Please visit the plugin configuration page, and enter a port (e.g. COM1) then restart iHS.Startup Complete, 1 errors detected, check the log for more information.
Weird point. This message is not in the log from the web page:
8/13/2013 6:19:21 AM
Web Server
Web Server authorized local login successful from: 192.168.2.2 User: default
8/13/2013 6:19:18 AM
Startup
Start up complete.
Startup
HSSentry is disabled in Setup, sentry will not be started.
TTS
Speak ():Welcome to Home-Seer
Startup
Scripting is OK and is now running Startup.txt
Startup
Running the Startup.txt Script
Startup
Starting DDNS service...
Startup
Updater services starting...
Startup
Starting Event Scheduler...
Startup
Speech
Listening for remote speaker connections on port 10401
Startup
Initializing Speaker Client Interface
Startup
Start automation engine...
8/13/2013 6:19:17 AM
Startup
Creating ASP.NET application host...
Web Server
Web Server started on port 82
Web Server
UPNP Discovery started
Web Server
Local IP address (subnet) is: 192.168.2.2 (255.255.255.0)
Info
Plugin Insteon with instance: has disconnected
Plug-In
Finished initializing plug-in Insteon
Hope this helps.
not sure, i'll have to try hs 3.0.0.17 firstMark
HS3 Pro 4.2.19.5
At this point it seems fair to say that the H3 architecture is fluid enough for you to expect each build to break you plugin. Users of this plugin should probably ask Mark to test prior to updating if they are using H3 for live operations.
CMHomeSeer Version: HS3 Pro Edition
Operating System: Microsoft Windows 10 Pro
Processor Type and Speed: i7 - 3.26 GHz
Total Physical Memory: 16Gig
Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
Insteon
3.0.0.18 and Insteon 3.0.0.9 work fine.....
Hardware :
Aeon Labs zstick, Insteon Hub, RFXCOM Lan, Current Cost Envi R, Davis Vantage Pro II, Boltek Storm detector
Software :
HS2 : No more used
HS3 Pro 3.0.0.18
Weather Display 10.37 build 69
NextStorm 1.8
Plugins :
HSTouch server 3.0.0.7, android client 1.0.0.44
Zwave 3.0.0.3 : 2 Siegenia CO2 Sensors, 12 Fibaro Wall Plug, 2 Everspring Flood sensors
Current Cost 3.0.0.8
Insteon 3.0.0.9 : 15 On/off plugs, 3 Dimmer Plugs, 2 Open/Close detectors, 3 Mvt detectors
BLLAN 2.0.5.0
What's the problem?
I *just* installed the HS3 Insteon plugin tonight.
Why is there only a 9-day grace period? I think it not right to purchase software that is not working yet.
I installed 3.0.0.2 HS. Tried installing the 3.0.0.9 plugin and it was not recognized. I updated to 3.0.0.18 of HS and the plugin is now recognized, butlike others I am seeing:
8/22/2013 11:20:37 PM ~!~Error~!~Initializing plug-in(1): Insteon Instance::Please visit the plugin configuration page, and enter a port (e.g. COM1) then restart iHS.Startup Complete, 1 errors detected, check the log for more information.
I see no place at all in the configuration to modify the COM port (mine happens to be COM4). I also see no place in the Web Interface to modify the COM port.
So, is there any way to extend the grace period until I know the software is working? and any idea why this is not working yet?
Win 7, 32-bit
