Try a factory reset of the hub then see if you can access it from HS. It won't help you with Echo, but at least you'll be able to determine the hub is OK with HS.
If it's not credentials, then the only other thing I can think of is that the Hub 2 can only accept one IP connection. You could determine that by monitoring the IP conversation from/to the Echo.
BTW, how does it sound audio wise?
