Cant get to Alarm - BLRF -> BLRadar -> BLSecurity
    Hi ALL
    I've got a CMS18 X10 movement sensor on A1. I've defined it in BLRadar as virtual A8 as a motion sensor.
    With this configuration I see the X10 received messages from A1 in the log ie: on/off. Since BLRadar is installed, the A1 device isnt updated anymore and the echo/noecho is now shown properly in BLRadar.
    I'm trying to trigger a device in ARM mode, I've tried setting up the device in BLSecurity with either the physical A1 device and the Virtual A8 device.
    I cant get the sensor to trigger BLSecurity.
    Am I supposed to use the A1 physical device or A8 virtual device and also do I need to set the "value triggered device" and what are those values :-)
    Understanding this would help me elsewhere !
    Many Thanks..Pete
    HS 2.2.0.11
    Is BLRF seeing the sensor?
    If you set up value triggered in BLSecurity you will need to specify the ON and OFF value
    If HS3 is triggering a value change on it then the plugin will get the callback
    Cheers,
    Bob
