Originally posted by MNB
View Post
I expect that you will find that the UUID and Major/Minor IDs are all the same. You can leave the UUID, but differentiate the major /minor between beacons using the Rad app. Set the minors differently for each is what I do.
When you trigger the webhook test it should then create different HS3 devices for each beacon under a group for your phone. If you've created GeoFency fences, those should also be in the group. For a second user (2nd phone with GeoFency) those devices will be under a different group in HS3.
