I have one door from the garage that has a z-wave sensor on it. I never got around to adding it to the caddx system with a proper sensor.
When coming from the outside the alarm "coming home" timer is triggered by the garage doors that do have caddx sensors - so you can't get into the house without setting the alarm off.
However, when armed - stay and we are in the house I would like the opening of this door to trigger the timer, requiring input of the code in the keypads, when opened from the inside.
So I want to trigger an event that triggers the alarm system. I only see Arm, Arm - Away and Disarm as actions, and toggle chime. Is there any way to trigger the coming home routine with warning beeper and requiring the code be entered? Thanks.
