Hallo again
I do not believe that it should be like that and that you have that problem or that all just get use to that. 3-5 second delay before sensor and light on.
It looks the way that when you going in to the room light is switching on after 3 to 5 seconds so on the staircase the light is on when you already lest the place.
The question is what makes that delay
When I am manually clicking on ON button it switches on instantly in the same second when I am testing the sensor it show movement on the screen in the split of the second?
Do I need separate better PC to run HS? Or RFXCOM should be not LAN only USB but that should not react so fast when I am pressing on button manually?
What to do??
What to do??
