ControlThermostat - THM Script Help
    I'm new to HomeSeer and scripting - so excuse me if my problem is obvious.
    I'm running HSPro rev: 2.4.0.6
    I've installed a Trane Zwave thermostat and am trying to figure out how to write a script to control it (and learn how to write scripts) based on various conditions.
    The following script only writes Time and "Status" in the log, the rest is blank and the thermostat setpoint does not change:
    Sub Main
    ' get the current temperature
    dim temp
    temp = hs.ControlThermostat("Q24","GetTemp",0)
    hs.WriteLog "Status", temp
    ' set the set point to 55 degrees
    hs.ControlThermostat "Q24","SetSetPoint",55
    End Sub
    In the status screen, the Thermostat is listed as Q24 and the child Temp value is Q25. I tried changing the first Q24 to Q25 and that didn't work either.
    Any help would be appreciated.
    Alan
    See this post for the correct use of the thermostat api.
    http://board.homeseer.com/showpost.p...21&postcount=6
      This doesn't work? Saved as stat.vb in your scripts directory? What version of HS are you running?
      Sub Main(parm as object)
      Dim pi As Object
      Dim setp,mode,temp As String
      Try
      pi = hs.Plugin("ZWave Thermostats")
      temp = pi.GetTemp(2)
      setp = pi.GetHeatSet(2)
      If(pi.GetCurrentMode(2)=0) Then
      mode="Off"
      ElseIf (pi.GetCurrentMode(2)=1) Then
      mode="Heat"
      ElseIf(pi.GetCurrentMode(2)=2) Then
      mode="Cool"
      ElseIf(pi.GetCurrentMode(2)=3) Then
      mode="Auto"
      ElseIf(pi.GetCurrentMode(2)=4) Then
      mode="Aux"
      End If
      hs.writeLog("debug","temp=[" & temp & "] setp=[" & setp & "] mode=[" & mode & "]")
      Catch e As Exception
      hs.WriteLog("debug", e.Message)
      Finally
      pi = Nothing
      End Try
      End Sub
        Try this
        Dim pi As Object
        Dim temp as Double
        temp = pi.GetTemp(1)
        hs.writelog("test", temp)
        End Sub
          I added:
          Dim temp As Integer...
          2/8/2010 2:39:14 PM test 67
          2/8/2010 2:39:14 PM Event Running script in background: Thermotest6.vb
            So now you are on your way. Download the HomeSeer SDK from the updater and have a look at the calls that can be made using the Thermostat API. I'll edit a few of these posts out to clear up and confusion.
              Thanks. I seem closer, yes.
              I tried ... CmdSetHeat(1,50)
              and I got a return from ... GetHeatSet(1) that is set to 50. However, if I look at the Trane thermostat, it is still set at 55.
              Any other great words of advise?
              Alan
                Try
                Dim pi As Object
                Dim ret as integer
                ret= pi.CmdSetHeat(1,50)
                hs.writelog("test", ret)
                End Sub
                  Rupp,
                  That worked. However, I discovered also that it would not work unless my temp setting was greater than 55 deg. I appears to be a setting within the Trane thermostat.
                  Thanks for your help!
