I have just purchased the above units.
I have managed to link both into HSPro V2.5.0.49
I now have 5 new devices
The below all being elements of the HRT4-ZW I presume
1.Thermostat 10 Temperature
2. Thermostat 10 Battery
3. Thermostat 10 (Plugin)
The below all being elements of the ASR-ZW I presume
4. Thermostat 8 Switch Binary
5. Thermostat 8 (Plugin)
I have I Associated the 3. With 4. in group 1. This appears to be correct at when the HRT4-ZW swings around the set-point the ASR-ZW triggers.
I have I Associated the 3. Group 1,2,3,4,5 with HS.
Device 1. Is set to wake up every 5 mins and value 1 is set to 128 (as recommended in other posts)
Now for the questions.
Is all the above correct?
Device 5. Was a bit of a surprise as 4. is just a relay not a thermostat. I presume this is just how the HS plug-in works? Do I simply ignore this device?
I have tried to do simple schedule using events.
Basically
Trigger, at 08:00 :- Action, Device action , Thermostat 10 Temperature (device 1.) = on
Trigger, at 20:00 :- Action, Device action , Thermostat 10 Temperature (device 1.) = off
The above appears to do nothing, Basically the system never turns off after 20:00
I also note that the device1. mode is always set to heat, there appears not to be any way to change this.
However device 4. dose change from heat to off depending whether the relay is on or off.
Is the above the way to setup a schedule?
Is this a poor compatibility issue with this device?
The only other device I can easily get a hold of in the UK is the EVR ST814.
I also have a Plugin question but I will keep this separate.
Thanks for any pointers.
Basically
