What is the correct way to install the latest zip file?
I copied all the files from the zip file, and placed them in the proper directories, replaced the files located in the Homeseer root directory and managed to break it.
The IM device says connecting, the homeseer log files says it is connected, but there is an error in the homeseer log file when I hit the apply MSN parameters.
12/9/2009 6:16:03 PM - IM Connector - Unexpected error occured while trying to disconnect previous MSN network object:An established connection was aborted by the software in your host machine
It sounds like there is a previous instance still alive, is that possible? Any suggestions?
