Hi, looking for a point in the right direction on this issue. I have a new build of Homeseer that I'm trying out to replace my Vera box.. must say I've loving it so far. I've got 3 Chromecast devices only 2 of which are active on the LAN at present. Both are never showing as connected but earlier today I did see the status was updated on the Nexus player when both Youtube and Plex when in use but I don't think the play/pause controls worked. Just now I've had the Chromecast Audio connected up for 2 hours and its not updating at all. Again all still showing as Disconnected. I've also turned off the "Last Change time" option and they don't seem to be being polled very often. Over 90 minutes ago at present.
Current Date/Time: 2/11/2018 11:43:00 PM
Linux version: Linux HomeSeer 4.4.0-112-generic #135-Ubuntu SMP Fri Jan 19 11:48:36 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 2 Days 15 Hours 14 Minutes 59 Seconds
IP Address: 172.30.1.17
Number of Devices: 117
Number of Events: 4
Available Threads: 200
Enabled Plug-Ins
3.0.0.12: Chromecast
3.0.0.28: ImperiHome
3.0.1.190: Z-Wave
less /home/mark/HomeSeer/Config/Chromecast.ini
[CHROMECASTS]
9d7973864b1e21735c5bb70bda38f6ef###ipaddress=172.30.1.150
9d7973864b1e21735c5bb70bda38f6ef###port=8009
9d7973864b1e21735c5bb70bda38f6ef###name=Nexus Player
9d7973864b1e21735c5bb70bda38f6ef###type=Nexus Player
9d7973864b1e21735c5bb70bda38f6ef###enabled=True
9d7973864b1e21735c5bb70bda38f6ef###online=True
9d7973864b1e21735c5bb70bda38f6ef###tts=True
abcd1234###name=ChromeCast
abcd1234###ipaddress=192.168.1.151
abcd1234###online=True
Mabcd1234###name=ChromeCast Audio
Mabcd1234###type=ChromeCast Audio
Mabcd1234###ipaddress=192.168.1.152
Mabcd1234###online=True
abcd1234###port=8009
abcd1234###enabled=True
abcd1234###tts=False
Networking
Sonicwall TZ300N, Homeseer and Chromecasts on the same subnet with the Wifi in bridged mode to the LAN subnet. UDP and TCP session times have been set to 5 minutes and 30 minutes respectively. All Chromecasts have static DHCP reservations but just dynamic ARP entries at present.
The server itself is an ESXi VM on a Dell server running Ubuntu 16.04LTS, I had to install mono-complete in order to get the plugin to work:
~$ mono --version
Mono JIT compiler version 4.2.1 (Debian 4.2.1.102+dfsg2-7ubuntu4)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen
Log example of me restarting the plugin and mashing the Mute button in the Homeseer web UI:
Feb-11 22:25:49 Chromecast INFO Connecting to ChromeCast Audio
Feb-11 22:25:49 Device Control Device: Ground 2nd Lounge Root to Connect (1) by/from: CAPI Control Handler
Feb-11 22:25:49 Device Control Device: Ground 2nd Lounge Volume to Mute (-1) by/from: CAPI Control Handler
Feb-11 22:25:48 Device Control Device: Ground 2nd Lounge Volume to Mute (-1) by/from: CAPI Control Handler
Feb-11 22:25:47 Device Control Device: Ground 2nd Lounge Volume to Mute (-1) by/from: CAPI Control Handler
Feb-11 22:25:07 Chromecast INFO Connecting to ChromeCast Audio
Feb-11 22:25:06 Chromecast INFO Connecting to ChromeCast
Feb-11 22:25:06 Chromecast INFO Connecting to Nexus Player
Feb-11 22:25:05 Plug-In Finished initializing plug-in Chromecast
Feb-11 22:25:05 Chromecast INFO Chromecast version 3.0.0.12
Feb-11 22:25:05 Info Plugin Chromecast has connected. IP:127.0.0.1:58330
Feb-11 22:25:05 Plug-In Interface Chromecast is running as a trial, 28 days remaining.
Mark
Number of Events: 4
Enabled Plug-Ins
3.0.1.190: Z-Wave
[CHROMECASTS]
Networking
~$ mono --version
TLS: __thread
SIGSEGV: altstack
Architecture: amd64
Disabled: none
Misc: softdebug
GC: sgen
Mark
