Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > DirecTV for HS3 (3P)
DirecTV for HS3 (3P) Descriptions related to the DirecTV plug-in for HS3.
Old February 16th, 2017, 04:11 PM
donstephens's Avatar
donstephens donstephens is offline
OverSeer
Issues with Clients
Just bought this plugin. Impressive.
I have four clients, which I can change channels but can not turn on or off.
The main Genie does respond to off and on.
Any suggestions>
Don
Old February 16th, 2017, 04:15 PM
spud's Avatar
spud spud is offline
Moderator
It's a known problem, On/Off doesn't work for Genie clients, unfortunately the problem is not on the plugin side and I never found any explanation or workaround for this issue.
Old February 20th, 2017, 03:48 PM
OverSeer
Thanks.
Old February 27th, 2017, 02:34 PM
OverSeer
So, I'm trying to Power On the Genie itself with the command
PHP Code:
hs.PluginFunction("DirecTV""MEDIA""SendRemoteKeyCmd", New Object() {"Power On"})
Which isn't working. Is my syntax incorrect? I can control the power from the DirecTV Remote Control.
Old February 27th, 2017, 04:17 PM
spud's Avatar
Moderator
Quote:
PHP Code:
sorry, I should have mentioned that in the user guide, the possible values for the key parameter are:
"power", "poweron", "poweroff", "format", "pause", "rew", "replay", "stop", "advance", "ffwd", "record", "play", "guide", "active", "list", "exit", "back", "menu", "info", "up", "down", "left", "right", "select", "red", "green", "yellow", "blue", "chanup", "chandown", "prev", "0", "1", "2", "3", "4", "5", "6", "7", "8"
, "9", "dash", "enter"
Old February 27th, 2017, 04:24 PM
OverSeer
Ah, I see.
HTML code is Off
Clients not responding properly / server issues phuz HS3Touch™ 15 August 30th, 2015 10:41 PM
collection of tcp clients travisdh Script & Plug-In Development 0 November 20th, 2012 11:05 PM
Clients won't connect 68sting Clients - Windows 3 December 12th, 2010 10:39 PM
Max Clients pscott HSTouch™ 4 November 22nd, 2008 02:59 PM
